1951 226H Harmonic Balancer
Just got a call from a local friend that is rebuilding my motor. He said the harmonic balancer has a bad crack in the key-way and the rubber is pretty much gone.
The number on the part is 7HT-6316. I was not able to find the part at the usual places, but was able to find one on Ebay that states it is for a 226H but the part number is 8HA-6316. I assume based on other parts this is from a passenger car versus a truck.
My question is, are there other sources for this part. If not, will the 8HA part on the a truck motor.
Thanks for the help...
Just got a call from a local friend that is rebuilding my motor. He said the harmonic balancer (damper) has a bad crack in the key-way and the rubber is pretty much gone.
This is the ID engineering number marked on the part, it's not the part number!
1948/51 226 I-6; 1950/53 254 I-6.
No Ford dealer or obsolete parts vendor has any.
8HA-6316-A is not the part number either.
Here's the pic of the 6312 section from the truck parts catalog. Do you see 6316 listed below 6312? No you don't because there's no such part number.
toofazt
10-10-2012 08:07 AM
