Sponsored by: Real Truck
not giveing up!!
Old Dec 10, 2017 | 06:59 AM
Sucker4aford's Avatar
Sucker4aford
not giveing up!!
Well hello everybody it's been awhile if anybody remembers my past threats the problem ended up being on my 2000 Ford F250 V10 gas, ended up being the alternator wires were switched when they were put on the alternator so it was running backwards the whole time so after all that fighting and being stumped for so long it ended up being as simple as switching to wires anyway that was probably maybe a year ago or close to it the trucks been running okay since then I've been using it been putting thousands of miles on it using it for my work truck I went out this morning started it up was letting it warm up in the driveway while I was sitting in it and all the sudden it just died I turn the key started for a second and died and then I turn the key again at nothing it was just the regular click everything came on but it was like the battery was dead engine wasn't turning over but it was kind of like try to a couple times real slow it turned over real slow and wouldn't start and then when I turn the key again it was like it didn't have enough power to turn over it felt like a dead battery but it was running fine for about 10-15 minutes before that just wondering if anybody has any thoughts on that like I said it's a 2000 Ford F250 with the gas V10 last year or maybe 10 months ago I put a new alternator solenoid has new fuel pump and fuel filters and that's about it it could use a tune-up but I don't know what the deal is with it dying today so if anybody has any thoughts or questions please ask sorry it also has a new starter I put in about 10 months ago
Old Dec 10, 2017 | 07:37 AM
seville009's Avatar
seville009
I’d check the battery to see if, in fact, it is dead or dying. Always try the simple stuff first.
Old Dec 10, 2017 | 07:42 AM
Chuck's First Ford's Avatar
Chuck's First Ford
as stated.. simple stuff first... and check battery connections.. not just look at them... if contacts are DARK.. clean all of them.
Old Dec 10, 2017 | 08:04 AM
irydasteelhorse's Avatar
irydasteelhorse
holy crap that was hard to read!
Old Dec 10, 2017 | 09:17 PM
fordmerc's Avatar
fordmerc
I agree! Punctuation goes a long way!
Old Dec 11, 2017 | 08:05 AM
WE3ZS's Avatar
WE3ZS
Oh, come guys, he did use one comma in that 317 word run on sentence (but no periods). I'm about the farthest thing from being an English Professor, I'm always misspelling words and screwing up punctuation............but at least I TRY, especially when I'm having a problem and soliciting help from others online!
OP, be sure to verify your battery's voltage, both resting and while cranking (or at least when attempting to crank). Also check you battery terminals for tightness and corrosion as well as the multiple grounds for the same. Good luck!
Old Dec 11, 2017 | 08:44 AM
rspeters's Avatar
rspeters
The "." key and "Shift" keys on his keyboard must be broken. The "," key went out towards the beginning of the post.
Maybe the keyboard realized what was going on and rebelled.
Old Dec 11, 2017 | 08:59 AM
99f350sd's Avatar
99f350sd
Make sure the engine turns over freely. The ac can lock as has happened before.
If you jump it and its good then you have a battery issue or a charging issue.
Old Dec 12, 2017 | 02:24 PM
TomTommy's Avatar
TomTommy
10 mins would be about the run time on battery alone. After the battery check, check your output on the alternator-both Amps and Volts. I've seen alternators throw 14 VDC all day long, but no amps.
Old Dec 12, 2017 | 06:05 PM
Lawnpro979's Avatar
Lawnpro979
This was a difficult read. But the solution may be as simple as jumping it off.........
Ive jumped my 2000 250 v10 a few times from lawnmower. Mine is used as a work truck too.
Bugzilla46310's Avatar
Bugzilla46310
Need to start a thread for the longest one "sentence" post.
Alex Mizzoni
Jan 6, 2019 06:47 AM
Teresa Welsh Leist
Modular V10 (6.8l)
Mar 18, 2018 11:12 AM
Sucker4aford
Mar 29, 2017 10:28 AM
Rusty_Old_F250
Nov 22, 2010 05:36 PM
79camperspecial
Electrical Systems/Wiring
Feb 28, 2005 11:36 AM
