Fuel pump issues!
Old Dec 8, 2017 | 02:54 PM
MikeTexas3878's Avatar
MikeTexas3878
Fuel pump issues!
My fuel pump is only getting 8.18 volts. Isn't it supposed to be getting 12 volts from the relay?
Old Dec 8, 2017 | 03:19 PM
exranger06's Avatar
exranger06
Yes, it should have 12 V. Have you confirmed the relay is putting out 12V? If so, the wire is probably damaged or corroded at some point, causing the voltage to drop. Probe the wire at various points along the length of the wire and check the voltage to narrow down where the damage is.
hongkongrider
Bronco II
Sep 23, 2018 01:21 PM
Clockwerk_rat
18
May 14, 2017 08:46 PM
Catchog
15
Apr 14, 2016 03:44 PM
hongkongrider
Bronco II
Nov 19, 2011 09:59 PM
RedRage
Jul 14, 2004 04:17 PM
