Bronco II Ford Bronco II
only 6.5 volts to the fuel pump
Old 11-11-2011, 12:33 PM
hongkongrider's Avatar
hongkongrider
hongkongrider is offline
i have only 6.5 volts to the fuel pump. 6.5 volts to the inertia switch. my gut tells me its the ECM am i missing something?
Old 11-11-2011, 06:19 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
You haven't mentioned what year it is.
Next would be to check voltage at the fuel pump relay. If it's old enough, there should be two relays on the passenger fender side. One is ECU, one is Fuel Pump
Old 11-12-2011, 12:14 PM
hongkongrider
it is a 1990 BII sorry for leaving that out. dont have too much experience in trouble shooting electrical so thanks for bearing with me on this.
just to let you know i have already put in a new relay and i still get 6.5 volts at pump. tried to check the voltage to the relay by removing the connector and checking the pins there. the drawing that i have in the manual indicates that red is the hot but i get no voltage there. checked all the others and now voltage so im doing something wrong. key is in the on position.
whats next?
Old 11-12-2011, 01:10 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
6.5 V along the fuel pump circuit (post relay) is fairly normal when the relay is open. I don't know enough solid state electronics to explain it, but it is a "ghost" voltage from inside the PCM.
The red wire is one wire that should have 12 V KOEO. The red wire comes from the EEC relay, which should be closed whenever the key is on. If that red wire isn't showing power, go back to the EEC relay and make sure it has power there and that the EEC relay is closing. Not only is it essential for this wire to have power, but the PCM also has to have power, because the PCM is responsible for closing the fuel pump relay.
There should also be a wire (at the fuel pump relay) from the fuse/fusible link that has 12 V at all times.
Old 11-12-2011, 01:18 PM
hongkongrider
there are 3 relays under the fuse box. i understand the fuel pump relay is the 3rd from the fire wall. which one is the ECC? based on what you said above i assume that the red wire into the ECC should have 12v as well?
Old 11-12-2011, 11:43 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
I'm not sure. Is there not a name for each relay in the power distribution box? Your wiring diagram should show the wiring to the EEC relay -- you may have to use that to identify which relay is the EEC relay.
Yes, and, assuming your '90 is the same as my '87 and '92, there are three pins assigned to that red wire at the PCM.
Old 11-15-2011, 01:50 PM
hongkongrider
ok this is where i am. checked voltages through the ECC relay. how power to the blk/ylw there. changed the relay and then got power to the new fuel relay connector on the red wire with ing on. checked voltage at the fuel pump and got these readings.
when the key is turn to ing i get 12v that then drops to 7v.
with key in the starting mode i get 12v.
fuel pump does pump for approx 3 - 5 seconds. i assume that this is to pressurize the system. checked for fuel at the fuel rail at the pressure valve point and no fuel. held the pressure valve open while trying to start motor but still no fuel. is there something else inline that could be a blockage? ran it 3 times with no fuel coming.
what am i missing?
Old 11-15-2011, 05:52 PM
Lead Head's Avatar
Lead Head
There are two fuel pumps. One on the frame rail, and one in tank. If the in tank one dies, you'll get little to no fuel at the rail. The frame rail pump is located behind a small metal cover on the drivers side frame rail, up front. You'll see it, the fuel filter will be near it as well.
Disconnect the fuel line before the rail mounted pump (just pull the little plastic clip) and have someone cycle the key and see if fuel comes out of the tank.
Old 11-15-2011, 10:08 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
The dual pump system was used up to '87 or '88. His is a '90, so it should have a single, high pressure, in tank pump. If he happens to have a "throw back" set up to the old 2 pump system, it would be important to know that both pumps are working.
If the pump is running, but no pressure is being generated:
1) Clogged filter
2) clogged pickup
3) other clogged line
4) bad pump
If you feel like you can do this carefully, disconnect the fuel filter, then run the pump briefly (you can use the fuel pump test lead in the self-test connector) and see if the pump is pumping anything to the filter.
Old 11-16-2011, 02:14 PM
hongkongrider
i have a new fuel filter and a new pressure regulator. the only thing left is the fuel pump. when i bench test it, it seems to run fine but perhaps it isnt putting out the pressure necessary. is there a way to test it for out?
Old 09-23-2018, 01:21 PM
John Finck's Avatar
John Finck
John Finck is offline
fuse!
fuel pup went bad on my F150, changed pump but only 6.5 volts to it. turns out it blew the fuse when it locked up. new fuse, now she's running like a top again!
fishingape
02-11-2015 01:46 PM
hongkongrider
Bronco II
11-19-2011 09:59 PM
bsparks72
1997 - 2003 F150
05-21-2010 07:18 AM
chipster6
1997 - 2003 F150
01-03-2007 10:55 PM
BIG DADDY 51
08-17-2002 03:47 PM
Quick Reply: only 6.5 volts to the fuel pump
