some engine details wanted
Old Dec 9, 2017 | 04:54 PM
bart f-350's Avatar
bart f-350
ok, but with a autobox you always have some slippage, unless in lock up.
btw, in a E4OD, the od is that a lock up (prise direct) or a real overdrive.
sorry, my questionmark doesn´t cooperate.
Old Dec 10, 2017 | 05:34 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Originally Posted by bart f-350
Well, I like to think more like: HP for speed, and torque to move things.
Thanks.
Think of it more like, torque is what gets you going, and horsepower is what keeps you going.
Going up an inch or two is hardly a difference you will notice. Even before my new engine, when i went from 265s and 4.11s to 255s and 3.73s the difference was negligible. Now, if you were going from 235s to like 37s, then yea, thats a big difference, but the difference between a 235 and 315 is only about 2" depending on the tire. That would drop your rpms about 200 at a given speed.
Here is a fun little toy Gear Ratio Calculator
Old Dec 10, 2017 | 08:05 AM
bart f-350's Avatar
bart f-350
actually I am thinking about this size, 325/85R16 which about equals 38x13xR16.
Thanks for the calculator,
Old Dec 10, 2017 | 09:05 AM
jayro88's Avatar
jayro88
HP is simple a mathematical calculation of your Torque at a certain rpm. If memory serves hp=(torque x rpm)/5252. So more torque at any given RPM will also give you more HP. The HP # for diesels do't go up as much with the added torque simply because the RPM # is much lower......it takes alot of torque to reach 300-400 hp at such a low rpm. The opposite of that is my cammed gasser track car. The cams didn't add a lot of torque, but it shifted the torque peak to much later in the RPM band. This resulted in a large increase in HP......and a vehicle that is not great off the line, but pulls very hard at higher RPMS.
My van has 235/85r16 with a c6+DNE2 OD and 3.54's. It does fine at 65-75mph on the highway and doesn't have an issue towing a trailer in the 6000-7000lbs range. Definitely not overly fast doing it, but it handles it fine.
For the best of both worlds you could add an aux O/D to your e4od and put in 4.10's or even 4.56's. You would have the gearing to get a heavy load moving as well as the number of gears to keep your rpm's lower at hwy speeds if you wanted to.....but for the $$ I would stick with the e4od/3.55s and add a turbo.
Old Dec 10, 2017 | 10:58 AM
bart f-350's Avatar
bart f-350
Jayro, what does mean DNE2 OD?
I might have forgot to mention here, but I have 1:4,10 in my axles.
Old Dec 10, 2017 | 11:05 AM
jayro88's Avatar
jayro88
DNE2 is a Doug Nash Auxilary overdrive/gear splitter. It bolts to the back of my c6 to give me an Overdrive (4th gear). I can also use it to split gears 1-3 for a total of 6 forward gears and 2 reverse. Basically it gives me 1, 1.5, 2, 2.5,3 and Overdrive.
They are not manufactured anymore. I purchased mine used from a forum member.
The only aux overdrive that is still being manufactured as a bolt on unit is the Gear Vendors.......and they are very pricey new.
Old Dec 10, 2017 | 11:16 AM
Macrobb's Avatar
Macrobb
Doug Nash bolt on Overdrive unit.
I don't own one.
Gear Vendors also makes a bolt-on overdrive unit that bolts to the back of the trans or transfer case, and gives you an extra top gear(overdrive) on top of whatever gear you are in. So you can "split" gears.
Here's a nice chart with ratios: https://www.gearvendors.com/fdrive.html
Remember that a final drive ratio is "how many revolutions of the engine it takes to turn the wheels one revolution", so you can then take an RPM * 60, divide it by the final drive ratio, multiply by tire circumference(2 * pi * radiusOfTire) and divide by 12 to get into feet, by 5280 to get to miles.
so:
( RPM * 60 / finalDrive) * (2 * pi * r) / (5280 * 12)
2000 rpm, 2.43 final ratio(GVOD + ZF5 in OD), 15.85 radius tires(235 85 R16):
(2000 * 60 / 2.43) * (2 * 3.14159 * 15.85) / (5280*12) = 77.6 MPH
Plug it into a calculator and play with it if you want.
toddpyles33
Dec 28, 2012 09:26 PM
ChrisFromTheForest
5.0L Coyote
Mar 14, 2011 11:16 PM
haakeye50
Feb 21, 2009 06:50 AM
alteredspeed
15
Aug 31, 2008 01:42 AM
lpg333
24
Jan 3, 2006 06:21 PM
