Super Long Start
Old Dec 6, 2017 | 04:31 PM
mara6.0's Avatar
mara6.0
Super Long Start
I have a problem every time I start my powerstroke after she’s been sittin for over a day. If I go to start her up she will turn over for about 15 seconds before she actually fires up. About midway through the cranking the oil gauge will jump from zero to half. She sits in a garage kept at about 40 degrees with no engine block heater. Is it just too cold for her to start right up? Asking because my cummins will start right up after a month of not been started.
Old Dec 6, 2017 | 04:42 PM
WatsonR's Avatar
WatsonR
What year?
Try parking the truck nose down (put a couple blocks under the rear) and see what happens.
Plugging in will help for sure.
Have any gauges to read live data to see what's taking so long?
Old Dec 6, 2017 | 05:38 PM
bismic's Avatar
bismic
Also -
Glow plug issues will typically throw codes.
Check to see what the oil temp is reading at KOEO (before trying to start) - after the truck has been sitting overnight.
What rpm's are you getting when cranking?
What oil are you using?
Old Dec 6, 2017 | 06:01 PM
WatsonR's Avatar
WatsonR
And make sure the oil cap and filter are OEM. If they are not, it could allow the drain back valve to not be held down and the oil to drain back to the pan.
ltl_jrw
Oct 26, 2022 07:38 AM
JT250
22
Sep 1, 2015 08:30 AM
nmaine
Aug 14, 2014 07:56 PM
06 Beast
Jun 9, 2009 10:46 PM
7.3mule
Mar 20, 2009 10:13 PM
