Sponsored by: Real Truck
What is this plug?!
Old Dec 5, 2017 | 04:05 PM
StrokinIT2001's Avatar
StrokinIT2001
What is this plug?!
Found it hanging under my 4x4 relay box
Old Dec 5, 2017 | 04:08 PM
Chuck's First Ford's Avatar
Chuck's First Ford
looks like an air sensor... from the air box or air filter to throttle body inlet.
Old Dec 5, 2017 | 04:34 PM
Lawnpro979's Avatar
Lawnpro979
Yes it looks like Intake Ait Temp sensor....do you have a cold air intake system?
Some people leave these out...
Old Dec 5, 2017 | 04:41 PM
StrokinIT2001
Have an aftermarket intake filter and box but not cold air... does it need to be hooked up like will it cause problems?
Old Dec 5, 2017 | 05:41 PM
Lawnpro979's Avatar
Lawnpro979
if its aftermarket,you probably dont have a place to plug it into.....I’m not really sure of the consequences of Not having it..
maybe someone will chime in.....I’m a stock type of a guy....” getting older, and dont care anymore”
Old Dec 5, 2017 | 05:50 PM
Blue7.3's Avatar
Blue7.3
It's a stock sensor for the air box, if you have an aftermarket airbox fitted you only have to drill a hole and add a rubber grommet and fit the sensor in place, so long as the sensor did belong to the truck.
Old Dec 6, 2017 | 11:21 AM
brandon_oma#692's Avatar
brandon_oma#692
If you have anything other than the stock air intake just get it near the air filter. If you have the stock it will have a place for it.
Old Dec 6, 2017 | 02:16 PM
brian42's Avatar
brian42
Veteran: Navy
I zip-tied mine to the master brake cylinder when I did the 6637 mod.
Old Dec 15, 2017 | 06:13 AM
theenforcer's Avatar
theenforcer
X2 with Brian. I zipp tied mine to the inner guard under the new 6637 filter.
MHammer21
Dec 2, 2010 09:12 AM
NateDog07
Feb 7, 2006 08:57 PM
Don_Raja
1997 - 2003 F150
Sep 20, 2004 07:55 PM
ssKable
May 17, 2003 11:57 PM
