Rocker Arm Discrepancy?
Old Dec 5, 2017 | 12:20 PM
EllieMae94's Avatar
EllieMae94
Hello,
I have a pair of E7TE heads from a 351w roller block out of a '96 F250. They are the stock 1.6 rockers from the factory. I have removed the rockers out of both heads and noticed 4 of the 16 rockers have different shapes on the seats than the other 12. The grooves in the rockers seats are what I'm referring to.
Notice the grooves on the seat are narrower towards the spring side and wider towards the pushrod side. 12 of the rockers were like this
The other 4 were like this, wider towards the spring, narrower towards the pushrod.
So my question is, does anybody know why only a handful would be different. Whats also odd to me is out of the 4 oddball ones, 3 were on one head, and 1 on the other head. Does on orientation matter? Any insight provided is greatly appreciated!
Old Dec 5, 2017 | 02:28 PM
Glaser67's Avatar
Glaser67
I believe those grooves are there to provide oiling across the fulcrum(?) and have no idea how or why they would be different. I'm thinking that because of the back and forth motion, the direction should matter at all. I cant confirm that, but if your worried perhaps someone else can chime in.
Thanks,
-Glaser67
Old Dec 5, 2017 | 04:46 PM
baddad457's Avatar
baddad457
Thanks,
-Glaser67
just oiling grooves, apparently mixed rockers from two different production run. They probably all got dumped into one bin at the engine plant. Nothing to worry about. Congrats though one having a discerning eye to catch that. You'll go far, Pilgrim ! ( one of my favorite movie lines from Jerimiah Johnson )
Old Dec 5, 2017 | 06:17 PM
Filthy Beast's Avatar
Filthy Beast
If the way they're set up now bothers you, pull out the offending ones and turn 'em 180*......
As baddad457 said, "Nothing to worry about."
Old Dec 5, 2017 | 08:45 PM
baddad457's Avatar
baddad457
Originally Posted by Filthy Beast
If the way they're set up now bothers you, pull out the offending ones and turn 'em 180*....."
I hope that was a joke
Old Dec 5, 2017 | 11:49 PM
EllieMae94's Avatar
EllieMae94
Very well, thanks everyone for their input!
lannondiesel
Oct 14, 2014 06:12 PM
david00f150
16
Jan 26, 2010 11:16 PM
FordPerf300
Sep 17, 2006 03:31 PM
skud
Jul 26, 2001 10:20 PM
