it feels like kicks
Old Dec 4, 2017 | 03:15 PM
juliolop's Avatar
juliolop
it feels like kicks
when I start my truck I feel like a little kick when I'm stopped and once you're moving and the truck is gaining RPM and going up in gears, sometimes you feel like a hit or a jump, don't know how to define it, can it be an ignition coil?
Old Dec 4, 2017 | 06:35 PM
1saxman's Avatar
1saxman
Transmission or ignition most likely. I had something like that once on a '90 Escort GT. I had replaced the spark plug wires but not the coil wire. It would 'jump' like that and throw a light. I took it in several times and they always replaced the mass air sensor - then it would do it again. Finally it did it and the engine wouldn't run anymore. They towed it in and it turned out to be the coil wire.
So I'd say there's a good chance you're experiencing something similar, perhaps in the power supply to the banks of COPs.
Old Dec 6, 2017 | 09:32 AM
Garden Spyder's Avatar
Garden Spyder
Amazon Amazon
Buy yourself one of ^^^ those dohickeys, from the Amazon link, set up the Bluetooth to your android phone (doesn't work with iPhones) download and buy a 5 dollar app called Torque Pro, link it up, go to "test Results" drive for 5 miles, with the app running, and park, but don't shut anything off. scroll to the bottom and find engine misfires, keep scrolling down and you will see each cylinder misfire count separately.
At this point, my suggestion would be to replace the spark plugs and coil packs for each cylinder that has misfires, until you get it down to a point when all of them are running almost completely perfect.
If that doesn't solve it, you may have an injector problem. Also, if you can't fix it with a hammer, it must be an electrical problem.
Old Dec 14, 2017 | 02:13 PM
bigdaddyII's Avatar
bigdaddyII
My little brothers 08 4.2 liter did this about 4 years ago. Changed the spark plugs and that cured it.
Old Dec 14, 2017 | 06:38 PM
1saxman's Avatar
1saxman
I'll watch for that on my 4.2L but since it only has 25,500 miles, it might be quite awhile before the plugs go bad.
Old Jan 15, 2018 | 07:36 AM
juliolop's Avatar
juliolop
thanks for the suggestions, I was out of the country but some relative kept the truck moving, right now there is not any noise or kick, I'll be alert to change spark plugs and coils and first time, thanks to everybody
Old Jan 15, 2018 | 09:30 PM
Ted928's Avatar
Ted928
This thread documents how I found my misfire
https://www.ford-trucks.com/forums/1...-no-codes.html
mroth2008
1983 - 2012 Ranger & B-Series
Nov 22, 2017 12:40 PM
Mr. Green Jeans
Feb 27, 2010 07:04 PM
maddmudder13
Aug 21, 2006 09:12 PM
pike_hunter
Feb 22, 2006 11:08 AM
JWtate1971
1997 - 2003 F150
Aug 18, 2004 04:42 PM
