#8 misfires P0308
#8 misfires P0308
F150 2001 supercrew 4.6l 42k milesThanx for the all the help I've received already. My #8 cylinder is misfireing. I was told it was the left side all the way back. Is this correct and if so, now what. I've already changed the fuel filter, sparks, and added fuel injector cleaner. The cleaner didn't work so I figure I need to get that specific injector thoroughly cleaned out right?
Okay so I pull the plug off the spark and see if I get a spark off the pulg? New to this so take it easy. Do I need special equipment to test this? I've seen people pull plugs then use scredrivers or something to test to see if the wire is good and it's getting juice to the spark. How can I check to see if power is going thru the cable without any equipment?
papatango
1997-2006 Expedition & Navigator
01-09-2015 09:54 AM
diablodude64
02-20-2012 04:01 AM
glkearns
12-06-2008 01:48 AM
msm7c
1997 - 2003 F150
05-07-2005 06:11 AM
