need so help
Old Dec 12, 2017 | 08:17 AM
DIYMechanic's Avatar
DIYMechanic
You should see something close to 20 PSI while cranking. Stuff some rags down there as fuel may spray a little when you're testing or removing the gauge, but you should see pressure while cranking.
It sounds like the fuel pump is moving fuel, though, as you said it filled the filter housing, but it's still best to confirm with a pressure gauge.
Any chance the IPR connector got bumped loose while you were working in the valley? Or that the fuel bowl wiring harness (which has the IPR wiring in it) didn't get reconnected? I guess I'm assuming you had the bowl out while you were replacing the pump...
Old Dec 12, 2017 | 09:32 AM
BuddyBarnes's Avatar
BuddyBarnes
If you disconnected the fuel lines from the back of the heads, I would think it is going to take some cranking to fill the heads with fuel and build pressure. How much cranking have you done? Keep the batteries charged.
Old Dec 12, 2017 | 09:33 AM
BuddyBarnes
This is why I love my E- fuel.
Old Dec 12, 2017 | 03:41 PM
knottyrope's Avatar
knottyrope
took mine a while to prime but not long to start up once primed
are you getting any smoke when cranking?
hopefully you didn't disturb the GPR wires, its a bit cold out to start with out GP unless its heater is plugged in
Old Dec 17, 2017 | 01:48 PM
kupiec20's Avatar
kupiec20
Ok. So i THOUGHT i was getting fuel to the fuel bowl. But im not.
So im thinking it was never the fuel pump?
But anyway i have a new fuel pump.
So is there an issue in the fuel tank or tanks.
If i just switch tanks wouldnt that fix the issue?
I need help. Ty
Old Dec 17, 2017 | 01:57 PM
97-psd's Avatar
97-psd
Maybe, but it could be the selector valve itself. Switch tanks and see what happens
Old Dec 17, 2017 | 03:27 PM
madpogue's Avatar
madpogue
How have you determined that you're NOT getting fuel to the fuel bowl? Earlier you said the fuel bowl overflowed. That would indicate at least the primary stage of the pump is filling the fuel bowl.
You did reinstall the filter, right?
Old Dec 19, 2017 | 08:06 AM
kupiec20's Avatar
kupiec20
just a question. can I draw fuel from a 5 gallon can? run a fuel line from the right side of the pump to the can? would that give me any answers on whats going on? ive been without my truck close to a month. a little frustrated.
Old Dec 19, 2017 | 08:44 AM
knottyrope's Avatar
knottyrope
yes you can use a can but put the return line to the can as well or it will go to tank
Old Dec 19, 2017 | 09:57 PM
Talyn's Avatar
Talyn
It took me 3 days to do mine in 30 minute intervals.
I'd try for a bit and give up and come back an hour or 2 later.
Eventually i got it, with the turbo in. It's a sombitch.
07Wolfie
Sep 11, 2018 07:51 PM
cline9394
Oct 21, 2015 10:43 PM
nateraz1
Jun 6, 2013 08:54 PM
pittmick
1997 - 2003 F150
Apr 5, 2012 12:54 PM
fordpride
Jul 25, 2010 12:09 PM
