Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Seat Heater
Old Dec 4, 2017 | 02:36 AM
Suprawill1's Avatar
Suprawill1
Seat Heater
Hi All,
Has anyone replaced the OEM heaters with aftermarket? Any problems aside of probable connector mismatch?
Thanks.
Will
Suprawill1 Posts: 136E-C LEVEL 2Congratulations on reaching 100 posts!Joined: December 11th, 2013, 10:13 pmMy nickname: Suprawill1My vehicle: '05 Escape Limited
Old Dec 4, 2017 | 05:44 PM
scott91370's Avatar
scott91370
I never had to replace mine but as far as the connector the new set should come with the end attached to the heater and the part that comes the electrical side. These will connect with the connector you mention. I mention all this for so,some who maybe hasn't ever done anything like this before, may e make it easier.
What I would do is leave the factory connector in tact but cut it as close to the original seat heater as possible then wire in the replacement part to that. This way the harness on both sides are still connected and if you ever want to go back to a factory it's sim atill,plug anemic play.
Old Dec 4, 2017 | 06:02 PM
Suprawill1's Avatar
Suprawill1
Thanks for the hit Scott91370. That's my plan exactly if the universal connector doesn't fit directly. Another concern is that most of these new heaters come with a whole new harness system with a hi and lo switch setting. If I connect the pads like we discussed, the OEM system which is just an on/off system will probably default to the hi setting and that may be too hot for continuous use.
Old Dec 5, 2017 | 05:52 PM
scott91370's Avatar
scott91370
Good point. I guess it's a try and see with a maybe having to cut the factory harness. Bummer!
Old Dec 6, 2017 | 12:08 AM
Suprawill1's Avatar
Suprawill1
Yes sir. Trial and error.
Old Dec 16, 2017 | 09:50 AM
5851a's Avatar
5851a
I would be happy if you could extend the on time of the factory, but figure it must be a durability issue.
ArmamentDawg
2015 - 2020 F150
Jan 29, 2019 06:43 PM
Hammer19D
Jul 28, 2018 01:26 PM
japaleno
16
Mar 12, 2012 10:33 AM
fords_forlife
Jul 1, 2006 10:40 PM
dhcram
1997 - 2003 F150
Dec 14, 2004 11:34 PM
