2007 F-150 5.4 4X4
2007 F-150 5.4 4X4
I have a F-150 5.4 4x4.
I am wanting some opinions on transmission. My truck transmission has never been serviced. Truck transmission has no problems ever and is the original transmission truck has 2 hundred thousand plus miles.
transmission color looks fine.
wondering if I should change the fluid and filter Help.
Don't fix it ?????
This is really transmission abuse.. The sooner it is removed and replaced the better. I would DRAIN and REFILL after cleaning the pan. I would NOT do a pressure flush and fill. You might loosed up some crud deposits in the corners and get it mixed in the oil.
What I meant was since the OEM Ford transmission fluid has worked well and for so long in the transmission without any problems, why change to synthetic transmission fluid. Just continue to use the OEM Ford transmission fluid.
Also in my first reply, I did suggest that since it`s been so long that yes, it needs to be serviced.
dafunkdawg
01-29-2005 09:02 AM
