idling issues.
12-01-2017, 10:03 AM
on
idling issues.
08 F350 6.4 with DPF delete and flash tuned. exact tune is unknown. after warmup I have a miss when idling.
12-01-2017, 10:19 AM
on
is it present if the AC is off?
12-01-2017, 10:25 AM
on
Thanks for the reply Robert. It did it this morning with the heat on. I keep the climate controls on auto. I will turn it off when I go to lunch today and see what happens. If it stops what do you think the issue may be?
12-01-2017, 11:00 AM
on
DPF-R units give a miss in the idle with the HVAC system on, nothing to be alarmed about
12-01-2017, 01:05 PM
on
Thanks for the info Robert. I checked it when I went to lunch and that is what was causing the miss. With the AC off it idles perfect.
12-01-2017, 01:14 PM
on
Glad to hear this one got resolved. I had never heard about that "symptom" of running those DPF delete plug ins with the AC on. Strange indeed.
12-01-2017, 02:30 PM
on
only issue for Shane going forward is a way to get back to stock if he ever decides to change tuners
The miss, and throttle response are the reasons I switched to the H&S
12-01-2017, 08:41 PM
Quote:
Originally Posted by
Robert Green
My truck does the same. That is totally wacky. I will have to turn off the HVAC as well and see what she does.
David Stadulis
06-13-2019 09:18 PM
TexasDiesel97
04-15-2009 01:16 PM
dep295
08-06-2008 06:11 PM
97Centurion
Modular V8 (4.6L, 5.4L)
05-22-2004 12:15 AM
