Engine oil type
Old Dec 1, 2017 | 11:52 AM
osalazar's Avatar
osalazar
Originally Posted by osalazar
what does LE stand for?
nevermind I got it. Thanks
Old Dec 1, 2017 | 04:30 PM
Timberwolf2017's Avatar
Timberwolf2017
Originally Posted by RJC2
That's because Rotella (called Rosmella by the Dodge boys) makes the Cummins smell like a polecat. I love Rotella oil, but quit using it when I had the Cummins. It smelled so bad that it was embarrassing to take my daughter to school.
The Powerstroke is a different animal all together. (definitely not a polecat)
I ran it for 2 years in my Cummins, never an odor. I run it in my agricultural equipment as well, never an issue.
Old Dec 4, 2017 | 12:33 PM
BII Plow Truck's Avatar
BII Plow Truck
It doesn't matter what your oil jug says, Ford says in owner's manual and the oil cap both say to use 5w40 synthetic if running bio-diesel.
Old Dec 4, 2017 | 01:27 PM
troverman's Avatar
troverman
Originally Posted by dnewton3
Any decent conventional HDEO 10w-30 or 15w-40 meeting Ford's current spec (a nod to their **** retentive desire for phos ...) will do fine in TX, and just about everywhere else.
What Ford "recommends" for some conditions leads folks to believe they must run a syn. That is not true at all. Ford only "recommends" grades for service factors. They "require" lubes that are licensed to their spec, to be covered under the OEM warranty. Although, lubes that offer their own warranty can also apply, as long as they are recommended by the aftermarket lube company for the application coverage (ie Amsoil, RL, RP, Valvoline, Castrol, etc). Warranty coverage needs to be understood in context of the M/M Warranty act, something else the bulk of the public grossly misunderstand.
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
Just don't waste your time thinking you need the "best" oil; there is no such beast. There are a lot of very good oils; all of which will protect the engine quite well. Use your time to worry about other things. And you don't need to spend a fortune on expensive syns, either. For example, there is Harvest King (the Rural King farm supply house brand) that is on the list in both grades. I also see Traveller (Tractor Supply house brand). Very economical and approved by Ford! House brands offer a very good value for the money, and still provide all the protection of OEM approval.
Great post! That's the thing, you can pay more for the "premium" brands but will your engine really last longer / regenerate less / get better fuel economy / have more power / run cooler? I doubt it. But many people will tell you yes.
In fact, Ford specifies a standard, non-synthetic 10W30 Motorcraft diesel oil. Some folks are spending well more than what the reasonably-priced Motorcraft costs...despite the truck coming from the factory with that very oil. Do they think their truck outperforms the way it did when it rolls off the assembly line?
I guess maybe if they add a little PM22 they'll be that much further along...
smlford
1983 - 2012 Ranger & B-Series
Dec 15, 2009 03:01 PM
Big-Red-Lariat
2004 - 2008 F150
17
Mar 11, 2008 05:07 PM
cparks
Oct 11, 2005 07:54 PM
HDMustF250
Feb 13, 2004 12:42 PM
andrewe
Oil & Lubrication
38
Feb 28, 2003 04:40 PM
