Can someone decode: E0SP-AA? I know it came off a 351W with a EO4D but the flex plate (or flywheel) is stamped with "AOD" on it? Does that mean its for a AOD or E4OD?
The flexplate must match the harmonic balancer. Install the wrong one, you will have a vibration that will eventually tear the center from the flexplate.
What year is the truck, what engine/trans?
its a 1995 351W with a 95 E4OD that's in a F-350 took the flex plate off to replace the rear main seal, the flex plate said "AOD" the trans was bad
(and also C5AE-A decode?)
(and also C5AE-A decode?) Whatever this is, it's wrong.
The flexplate you need was introduced in 1971 .. so it would not have a 1965 ID number marked on it.
D1ZZ-6375-A part number/applications source: 1980/89 & 1990/2001 Ford Light Truck Parts Catalogs.
if that is the wrong flex plate how can you tell if the torque converter is the right one? The only number I found on the torque converter that cam off the trans is 0245 and I can't find the ford part number
