Ranger Trouble
Old Nov 29, 2017 | 06:12 PM
GoofyF-150's Avatar
GoofyF-150
Ranger Trouble
Hello all ..
I am having trouble with my 93 ranger has the 4.0 in it it is 4x4 with a 5 speed tranny.. it has been driving great with no trouble at all and i came home with it and shut it off let it cool got ready too leave and it won't start !! I DONT HAVE SPARK !! I had the control Mod checked but that was through auto zone and it checks out good i have replaced the Crank sensor and the Ing switch and the key .. checked the fuses all good but found a 20 amp bad so i replaced it .. can somebody please help me . i know i am missing something but i just can't see what it is !! please any help would be great !!!!!
Old Nov 30, 2017 | 09:08 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
You've been busy on this puppy. Good idea to have checked for fuses.
What was the blown 20 amp fuse for?
Do the dash warning lights light up for their self test when you turn the ignition key to run? If not, try thumping, or wiggling the PCM power relay in the under hood power distribution box, to see if it'll wake up. If it does, inspect it's electrical pins & sockets for corrosion, or suspect it has internal relay contact problems, so replace the relay, as they're a known problem part.
If no joy with the thump/wiggle test, you could try swapping the PCM power relay with a like one not needed to run the engine & see if you get joy. If so, replace the troubled relay.
If the dash warning lights come on for their self test, the computer is getting power through it's power relay, so scan the computer for trouble code clues & post all code Numbers, as they can help focus a trouble shoot.
Seeing as how the 93 Ranger is OBD-1 diagnostics, you don't need a code reader, or scan tool to have the dash CEL, or test light, blink, or your analog multi-meter needle wave, any set trouble codes, by using one of these electrical hook-ups. http://www.troublecodes.net/ford/
Let us know what you find.
bristolstud2002
1997 - 2003 F150
Jun 3, 2021 06:21 AM
SARGE1
23
Dec 20, 2017 10:36 PM
msp252
18
Dec 13, 2015 12:56 PM
mrjones111
1997 - 2003 F150
Jul 24, 2013 12:33 PM
rancero86
Mar 23, 2010 06:23 PM
