No CEL no crank 97 Expy 5.4l auto trans 4x4
Checked:
~ Theft Light not blinking
~Turned engine over by hand
~Starter. Manualy powered it with jumpers and it was non functional. Replaced
~Starter relay on firewall. Supplied power to relay trigger and it tries to start so the relay is good.
~Tested for power at relay trigger wire when key is in start position, no power.
~Pulled all fuses to check continuity, all under hood were ok, under dash Fuse #6 a 5 Amp was blown, #21 a 15 Amp was blown #30 a 30 Amp was blown. Replaced all fuses necessary, but no CEL/Service Engine Light
~These fuses all have voltage in run under hood #19 20 Amp (fuel pump relay), under hood #24 30 Amp (PCM power relay), under dash #30 30 Amp (PCM Power Diode)
~PCM Power Diode has full battery voltage power coming in on the right terminal the Diode itself read continuity from right to left and OL from left to right in Run
~Checked the EEC/PCM Relay and Fuel Relay by swapping into the horns location and trying the horn, I can also feel the EEC relay and Fuel Relay click in Run, and when I get down by the tank I can hear the fuel pump prime
~Ensured trans in park and tried neutral and wiggling the steering column.
~Tested for power at fuel injectors and coils. Verified
~I plugged in XCal 3 and it can read the code p1000 from the EEC
~I cannot get the CEL to come on while its key on engine off not cranking
- I am going to pull the Gauge cluster to check the CEL bulb but I’m not thinking it’s that, when I replaced all the fuses the 4x4 light and other lights in the bottom corner came on except the CEL.
-Is there an easy way to check the stater interrupt relay, would it cause the CEL to not come on at all?
-I want to check the Digital Trans Range Sensor but need to know the wire color for voltage in from the the ignition switch, and the wire color coming out to the relay, would it cause the CEL to not come on at all?
-Besides checking voltage to one side of the Crank Position Sensor connector is there a way to test the sensor itself by reading the resistance or something?
-What else could cause the Service Engine Light to not come one, do I need a new EEC or DTRS, or is there more troubleshooting I can do to narrow this down?
-Is there a better way to verify EEC voltage and ground besides back probing the EEC connector stuck up in the dash?
If anyone would please get me the necessary Wiring Diagrams from an EVTM that would be much appreciated, I have the chipped keys and the theft light does not flash when key is on.
Checked:
Fuse #20 (50A)
light green/pink
to ignition switch
Then red/light blue
to fuse #21 (15A)
Then dark blue/orange
to DTR sensor.
Then tan/red
to starter relay on the fire wall.
fuse #20 has13v and is HOT at ALL times
checked the light green/pink wire there is none
there are two green\purple that do get power
red/light blue wire has no power from the switch
no power on under dash fuse #21 .60 on left terminal .09 on right
it looks as if the previous owner ran a wire from the red/light blue wire from the switch directly to the dark blue/orange wire at the DTRS connector and cut it there and spliced there's in bypassing fuse #21
no power
i know this just putting out there
Good news
I will thursday
ok good good
F21 can't blow again no power F30 is not open anymore and has voltage in run
Did it ever run in your possession, or did you just buy it in a non-working condition? Sounds like there's some hack job from the previous owner, I'll do you a solid. I have a 96-99 factory shop manual DVD in an iso file on my dropbox, I'll mail you a link. Be quick to download it though, the link expires in 6 or 7 days.
as long as i have a jumper from the positive battery post to the little relay input at the middle at the top it'll turn over, as soon as I let go the truck stalls
Will check the START position tonight
will check in start
That dark blue/orange wire is the circuit that passes through the DTR (neutral safety switch) section to eventually power the starter relay. If the DB/OG wire has no power on it then you have to trace it back to find out why not.
