Sponsored by: Real Truck
The ole, bouncing “hopping” when breaks applied
Old Nov 29, 2017 | 01:14 PM
Lawnpro979's Avatar
Lawnpro979
Angry The ole, bouncing “hopping” when breaks applied
After changing u-joints, shocks all around, breaks, hubs, 2 calipers,
i still have the hopping when breaks applied hard.....I started out just doing needed work on my 2000 250 SD 4x4 but was attacking this issue too. I need tires on the rear and plan on getting an alinement.....
the front tires are wearing funny an was going to purchase new ones for the rear and have the new ones put on the front.
balljoints, tie rod’s all look good. Also was going to replace the front stabilizer shock....
anything else anyone can think of to try to get rid of the bouncing when breaking hard?
thanks
Old Nov 29, 2017 | 01:49 PM
Deuce40s's Avatar
Deuce40s
I'd replace the bushings in the spring packs for sure. Ball joints and tie rods may look good but have enough wear to cause problems. Might as well replace them too. Your truck will thank you.
Old Nov 29, 2017 | 04:36 PM
Just Strokin's Avatar
Just Strokin
How old are the shocks? Worn out shocks will cause wheel hop when braking of the rear wheels.
Old Nov 29, 2017 | 06:05 PM
scottscott's Avatar
scottscott
Did you replace the brake rotors or have them cut? Warped brake rotors can cause a hopping or shudder feeling under braking.
Old Nov 29, 2017 | 06:22 PM
Lawnpro979's Avatar
Lawnpro979
Replaced rotors all 4, all 4 new shocks too. 2 new calipers.....
Old Nov 29, 2017 | 07:43 PM
geekwithoutacause's Avatar
geekwithoutacause
Ball joints !
How many miles on it ? or since last balljoint job ?
Old Nov 29, 2017 | 10:24 PM
Lawnpro979's Avatar
Lawnpro979
Ball joints checked. All good, along with tie rods...... its a head scratcher guys,,,
Old Nov 29, 2017 | 10:34 PM
m-chan68's Avatar
m-chan68
thanks
ANY time there is a complaint of shimmy, shudder or vibration occurring DURING BRAKING, it ALWAYS comes back to the brake rotor or drum surface. I can tell you I've pulled my hair out more than my share of times during my last almost thirty years of turning wrenches, by making the assumption new parts were "good" parts.
Before replacing any more parts (and wasting more money), I suggest you measure brake rotor runout with a dial indicator to see what readings you obtain (yes, even on brand new brake rotors), beginning with the front brake rotors (where most braking feedback will be noticed). It wouldn't be the first time I've had bad-out-of-box new parts, and likely won't be the last time.
Old Nov 29, 2017 | 10:37 PM
Lawnpro979's Avatar
Lawnpro979
ya know.....Ive thought about that. thanks
Old Nov 29, 2017 | 10:42 PM
geekwithoutacause
Yeah, or perhaps the tires?
Old May 29, 2018 | 09:04 PM
bubblegoose123's Avatar
bubblegoose123
Bearings
Anytime you replace the rotor, the bearings should be replaced as well. Just went through this myself, replaced rotor but reused bearings and it would shake while braking. Pulled the rotor, replaced the bearings and put it all back together - no shaking while braking.
F250_JR
15
Dec 1, 2010 09:21 PM
LA3
Nov 16, 2010 07:23 AM
Bill4042
Aug 17, 2005 12:27 AM
ifishwalleye
1997 - 2003 F150
18
Feb 6, 2004 09:25 PM
SteveM
20
Oct 21, 2003 06:49 PM
