What's my front end problem?
Old Aug 14, 2005 | 11:01 PM
Bill4042's Avatar
Bill4042
I've got a 00 4x4 which had a back shock break a few months ago, so the rear shocks were replaced, and the tires rotated front to back. The flat spots I noticed on the (now) front tire I atributed to the previously broken shock, after an alignment and and 3 balancings I decided to replace all the tires because I could not get the wobbling to stop. No dice. Still have steering wobble and some serious dash bouncing when braking. What could it be?
Old Aug 15, 2005 | 01:08 AM
Monsta's Avatar
Monsta
Sit. Stay.
Check the tie rods and ball joints.
Also sounds llike your rotors are warped.
How many miles are on your truck?
Oh...and welcome to FTE!
Old Aug 15, 2005 | 02:56 AM
Bill4042's Avatar
Bill4042
add to front end trouble
Thanks for some ideas, I did have the brakes looked at by two different shops, both said they looked good (you'd think they would notice something like warped rotors), but I'll have the rotors examined along with the tie rods and anything else anybody can come up with before tuesday.
The X has almost 115k on it now.
Last edited by Bill4042; Aug 15, 2005 at 03:08 AM. Reason: fixing one typo & trying to get signature to show up
Old Aug 15, 2005 | 06:35 AM
SpareTime's Avatar
SpareTime
also check the steering stabilizer.....although it may not be the cause of all the problems, it could sure be a contributing factor to the problem
Old Aug 15, 2005 | 09:29 PM
X 03 Jeff's Avatar
X 03 Jeff
If all they did was a visual inspection, They would not be able to tell completly if the rotors are warped or if they have high or low spots in them, they should be checked with the proper machine, or just ask them to try and turn them.
Jeff
Old Aug 16, 2005 | 02:20 AM
Bill4042's Avatar
Bill4042
now back in the shop
Tomorrow morning I will be picking up my X with two new front rotors, they say ball joints, etc. are tight. Yup, they had to use something to detect that the front rotors were indeed warped, but I've already forgotten the terminology. After some serious driving, (although I plan to be gentle with my braking for a time with the new rotors) I will post tomorrow night the results.
Thanks for the helpful suggestions.
Bill
Since the signature doesn't show, I'll just add here that I have a 00 Excursion
4x4 limited V10, a 00 Expedition 4x4 XLT 5.4, and an 89 F-250 diesel 7.3
Old Aug 17, 2005 | 12:27 AM
Bill4042's Avatar
Bill4042
The front rotors were definitely the problem. Thanks for all the help.
Bill
