Can’t get my steering column back together right. help
So I’m replacing the turn signal cam, and have gotten to the point where I put it all back together. I cannot get the top section of the column housing to seat flush to the bottom section that the shift arm goes into. Pictures below for reference All of them that I’ve seen are flush with no gap so I’m missing something obviously. It feels like something is preventing it from seating but I cannot see anything. Any suggestions?
Shift column
Does the shift tube still feel like it is still engaged with the shift lever at the bottom of the column? If it came up and was turned then the drive key that is welded to the tube is not engaged in the shift lever that goes to the transmission. You probably noticed that the square end of the retaining bolts have a groove that engages into the shift column mast jacket, they have to have the retaining nuts just barely started so that they will engage into their respective slots. Good luck, Kenny
I put the bolts back in, but I didn’t tighten them, because the don’t seem like they do anything. What exactly do those bolts hold together
75f100hsv
05-01-2019 11:24 AM
64blue
05-21-2008 02:54 PM
75f-250
08-09-2007 08:22 PM
