Hey guys, looking for a good quality spin on fuel filter conversion from the stock in line style. The connections on mine are binding so badly now that i haven't been able to change the filter. If any of you have recommendations it would be great!
I bought the fp-100 which is a 10 psi lift pump. I installed it in line , after thevtsnk, before the stock underchasid lift pump. Comes with everything. Costs a pretty penny .
You could probally splice in a radcor type filter filter in between your existing lift pump and on board engine filter. Stock engine filter is 5 microns so if you put a 2 micron filter in front of it, you would never have to change the engine mounted filter.
