1978 - 1996 Big Bronco
mulpha
Old Sep 11, 2003 | 08:30 PM
mulpha's Avatar
mulpha
Angry mulpha
Ok,
I got new monroe reflex shocks 4 up front. now at 67 mph, I get a terrible shimmy? tires have been rotated and didnt have this prob until shocks replaced.
suggesstions
Old Sep 11, 2003 | 09:35 PM
3broncocrazy's Avatar
3broncocrazy
mulpha
Sounds like either a weight has fell off one of your tires that was on the rear or you have a out of round tire. Did you rotate the tires yourself? If you did it or the tire shop - that's where it needs to go IMO
Good Luck
Old Sep 12, 2003 | 09:31 AM
BillyBob69's Avatar
BillyBob69
mulpha
Have the tire shop check the balance on your tires. Also if its been some time since you rotated till now, then you prolly have whats called "Cupping". This will fade as the tires wear since they were in a different spot before. Especially if you changed from side to side.
mulpha
Nov 10, 2003 07:38 AM
mulpha
Nov 4, 2003 10:28 AM
mulpha
Sep 8, 2003 11:05 AM
mulpha
17
Sep 5, 2003 09:24 AM
mulpha
Aug 29, 2003 07:17 AM
