Down Pipe
Old Nov 21, 2017 | 11:57 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Down Pipe
That down pipe is small. Going to 4”. EGT’s are going DOWN!
Old Nov 21, 2017 | 02:03 PM
z31freakify's Avatar
z31freakify
I dont see the benefit in going with the 4" down pipe on the super duty trucks, i could be wrong but thats my .02, the obs trucks do good with an aftermarket 3" down pipe.
Old Nov 21, 2017 | 02:11 PM
Whitey Ford
At the bend it is only 2 3/4”. We will see if it helps when the new EGT’s numbers dial in. Stay tuned!
Old Nov 21, 2017 | 02:23 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Whatever will those people who have aftermarket turbochargers because of huge injectors that move A LOT more air do about their 3" downpipes?
That pipe is not a problem at all and is plenty big. Oh well, it's your time and money.
Old Nov 21, 2017 | 03:12 PM
Brother Les's Avatar
Brother Les
Look for another reason on your EGT's
Old Nov 21, 2017 | 05:19 PM
Whitey Ford
We dropped 70 degrees at 60mph at the exact same conditions except outside air temp was 10 degrees warmer. 200 degrees at strong throttle.
Heat is waste and money. Saving the planet one 7.3 at a time.
Old Nov 21, 2017 | 05:31 PM
Whitey Ford
Originally Posted by cleatus12r
3" downpipes
Actually 2 9/16” at that lower bend. Made a big difference in EGT’s which as we approach 400,000 we would like to keep down. Thanks to your SUPER tunes we will probably make it to 1,000,000 miles.
Thanks again.
Old Nov 21, 2017 | 05:37 PM
Whitey Ford
We are pretty slow down here in the south, not sure we understand what you mean. We are running 500 degrees now at steady 60mph on flat ground with no head wind. That seems great to us. We will know more later as we haul cattle.
Thanks.
Old Nov 21, 2017 | 05:53 PM
Whitey Ford
You know who the heifers are watching when we pull up to the cattle auction, and it ain’t no $95,000 2017 F-350. They are looking at that 2002 F-350 7.3, and that ain’t no BULL!
We have FTE to thank for that!
Old Nov 21, 2017 | 07:05 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'm not saying you're wrong because only you know your pickup but I don't have any EGT problems with a completely stock exhaust system (except a straight-through 1995-1997 muffler, 250/200% injectors, 71mm turbo, and fat tires) while towing.
Who are you? MY tunes? When?
Old Nov 21, 2017 | 07:40 PM
Whitey Ford
We do not have an EGT problem either, we are just trying to improve heat numbers which will increase exhaust valve and motor life as we see it. We made a big difference for sure, and we wanted to share that information with others.
https://www.ford-trucks.com/forums/1...companies.html
Thanks again!
Old Nov 21, 2017 | 07:53 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
That's why I don't remember. I didn't actually write you any tuning. I just put the shift pressures back near to stock.
​​​​​​​Take care!
Old Nov 22, 2017 | 07:37 AM
Whitey Ford
​​​​​​​Take care!
You helped us out BIG when we needed it, and we really appreciated it.
Happy Thanksgiving!
Old Nov 22, 2017 | 09:05 AM
CousinCarl's Avatar
CousinCarl
Sure is a pretty rig, Mike.
Old Nov 22, 2017 | 05:44 PM
jstihl's Avatar
jstihl
hey whitey, I'm thinking of doing the same down pipe and installing a flow through muffler. How tuff was it to get the down pipe in? Any tricks?
