2.3 engine swap
Old Sep 11, 2003 | 05:45 PM
brevity1073's Avatar
brevity1073
Question 2.3 engine swap
What do ya'll think? I'm thinking about buying a brand new 2.3L for my '85 Ranger. This engine has everything--it's not just a long block. It has the fuel system and everything. How easy/hard would it be to swap it in? My Ranger only has 95,000 miles on it, but it is starting to smoke at startup and sitting at lights. I know that I could just keep on putting oil in, but I can get this engine for $600. No, it's not stolen.... Anyway, is this a feasible swap?
Old Sep 20, 2003 | 09:11 PM
DainBramage's Avatar
DainBramage
2.3 engine swap
Feasible, yes. But, I think, you could simply refresh yours, for a lot cheaper, and save the $$$. If it's smoking already, I'd bet it's simply valve seals.. Gonna cost you a lot less than an engine swap.
Beyond that, if I were swapping engines, I'd reconsider the 2.3.
If I was going to swap out my engine, I'd be looking for a 4.0 or 5.0 to drop in it, which, in all reality, wouldn't cost much more than what you're looking at doing now, maybe a few hundred.
Just my opinion..
Old Oct 2, 2003 | 02:34 PM
tomw's Avatar
tomw
Well, it'd be an unusual combo. I *think* you are talking about the new engine that topk the place of the Lima 2.3. You'd have to figure out fuel system stuff, ignition stuff, exhaust, bell housing fit. A whole bunch of worms that would gain about 20 hp and some torque. Probably a neat thing if you have lots of time, but as noted, there are more common swaps that gain a lot more for a lot less work.
JMO (just my opining...)
tom
Old Mar 26, 2007 | 01:11 PM
bryrykim's Avatar
bryrykim
i think that you can fix it really simply i had the same problem and for about 8-10 dollars you can go napa auto parts or relative part store and buy this stuff called sea foam and you add it to your crankcase and to your fuel
Iantiler
1983 - 2012 Ranger & B-Series
Nov 15, 2011 09:22 PM
ctango01
Engine Swaps
Apr 26, 2010 05:53 PM
ctango01
Apr 21, 2010 07:19 PM
Jent
May 24, 2005 06:42 PM
deltaranger
4 Cylinder Engines
Aug 16, 2004 01:10 AM
