Passenger Window Problem
Old Nov 19, 2017 | 03:47 PM
Aratic's Avatar
Aratic
Hello,
I recently changed out my Passenger window arm and motor on my 87 F-150 since it was destroyed beyond repair. Now however it seems that the window is binding as the window goes up. It is a little slow going down but the window does not stop but if i bring the window back up it binds to the point that the motor cant raise it. I would appreciate any advice any one could give me to try and fix this problem.
Old Nov 19, 2017 | 07:47 PM
Workingstiff's Avatar
Workingstiff
I'd guess its binding in the track.
Old Nov 19, 2017 | 08:07 PM
Aratic's Avatar
Aratic
Any possible fix for that.
Old Nov 20, 2017 | 07:54 AM
My4Fordtrucks's Avatar
My4Fordtrucks
There are or should be small adjustments you can make to how the regulator is secured to the door. Try backing off the bolts/nuts on the regulator and then running the window up and down.
Old Nov 21, 2017 | 07:46 AM
Aratic's Avatar
Aratic
I tried loosing the bolts and took the arm off and tried to move the window by hand to see if I get the same result. The window still binds about half way up.
Old Nov 21, 2017 | 12:31 PM
My4Fordtrucks
Felt/ window run damaged?
Old Nov 22, 2017 | 07:14 AM
Aratic's Avatar
Aratic
I don’t see any damage to the run but what felt was left was hard and Brittle but the window was running through that just fine.
Old Nov 22, 2017 | 12:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Aratic
Hello,
Nylon window roller (23240 in pic) clips to the stud of the window regulator (23200), then slides into the channel (21458) that the glass is adhered to.
If the roller breaks, the window binds up and/or falls down to the bottom of the door).
The nylon gear (D0AZ-62234A24-B) in the window motor (not shown in pic) is available by itself, so you don't have to buy a new motor (unless it has burned out).
Available from auto parts store and it's the same: 1970/91 FoMoCo Passenger Cars; 1975/91 Econoline; 1981/91 F100/350 & Bronco.
ddwood55
1978 - 1996 Big Bronco
May 24, 2016 04:09 PM
bgblktruk
Oct 1, 2009 01:25 PM
ty20404
Jun 24, 2008 05:26 AM
Bertha1
Sep 19, 2006 10:17 AM
