Sponsored by: Real Truck
folding mirror problems
Old Nov 18, 2017 | 10:26 PM
iron butterfly's Avatar
iron butterfly
Howdy, I've got a 2012 powerstroke f350 Lariat with a mirror that has developed a problem with the driver's side mirror. When it is folded in it will only fold out part way. I have tried syncing them to no avail. I found a motor kit listed on Ford Parts and would like to ask anyone that has installed one what it consists of. What I'm thinking is happening is the gear that sends it out is possibly slipping on the shaft as it operates erratically both directions but out is worse. Both directions pop a bit but it will fold in slowly.
Thanks in advance, with all my heart I don't want to drop $1200 on a plastic mirror!
Old Nov 18, 2017 | 11:45 PM
Evan_P's Avatar
Evan_P
I'm not sure what motor kit your seeing, but the folding mirror motors are not serviceable. You have to replace the mirror assembly...
Old Nov 18, 2017 | 11:56 PM
texinwa's Avatar
texinwa
Mirrors are cheap on ebay
Old Nov 19, 2017 | 12:07 AM
Sterling6.7's Avatar
Sterling6.7
They are serviceable, but not with factory parts. Here is a little info
Towing Mirror Gears - Ford Trucks - Gruven Parts
Power Folding Mirror Issues - PowerStrokeArmy
Power Fold Fix for $5 - Ford Powerstroke Diesel Forum
Old Nov 19, 2017 | 03:25 AM
seville009's Avatar
seville009
I’d try WD-40 first - I lube mine every year; helps alot as they seem to dry out easily
Old Nov 22, 2017 | 11:38 PM
iron butterfly
Thank you all for the replies and am going to try the gears from Graven parts. I'll update when I get them. All y'all have a great Thanksgiving!
Old Nov 23, 2017 | 01:21 PM
Jaime74656's Avatar
Jaime74656
sounds like (if the gears are plastic which i am assumeing they are) you just need a quick shot of WD040 silicone spray (yellow can top) and that SHOULD cure the issue unless the teeth are broken on one or more of the gears...I do not have power folding mirrors but I do the same for the window motors and regs with moving parts every so often (including the window tracks on the side)
Old Nov 25, 2017 | 12:58 AM
Sterling6.7
Looking forward to the update.....
Old Dec 10, 2017 | 10:45 AM
Sterling6.7
Any news on the repairs?
Old Jan 20, 2018 | 09:17 PM
Sterling6.7
Any updates?
Old Mar 21, 2018 | 08:41 AM
rob17's Avatar
rob17
Where did you apply the WD-40?
Rob
Old Mar 21, 2018 | 09:59 AM
seville009's Avatar
seville009
Rob
inside the pivot point where the mirror “hinge” is. Just stick the straw on the spray can as far inside the plastic cover as you can. I don’t take anything apart. After i spray it, i fold/unfold it a bunch of times to work it in.
Old Mar 21, 2018 | 10:03 AM
rob17's Avatar
rob17
Thanks so much, I'll give that a try.
Rob
ubereal2
2009 - 2014 F150
Apr 26, 2017 08:20 PM
antwan181
Aug 20, 2016 10:00 PM
kper05
6.7L Power Stroke Diesel
Aug 2, 2014 09:15 AM
zonedar
Mar 17, 2014 05:57 PM
66F100Again
May 22, 2009 02:59 PM
