1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
folding mirror problems
Old 11-18-2017, 10:26 PM
iron butterfly's Avatar
iron butterfly
iron butterfly is offline
Howdy, I've got a 2012 powerstroke f350 Lariat with a mirror that has developed a problem with the driver's side mirror. When it is folded in it will only fold out part way. I have tried syncing them to no avail. I found a motor kit listed on Ford Parts and would like to ask anyone that has installed one what it consists of. What I'm thinking is happening is the gear that sends it out is possibly slipping on the shaft as it operates erratically both directions but out is worse. Both directions pop a bit but it will fold in slowly.
Thanks in advance, with all my heart I don't want to drop $1200 on a plastic mirror!
Old 11-18-2017, 11:45 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
I'm not sure what motor kit your seeing, but the folding mirror motors are not serviceable. You have to replace the mirror assembly...
Old 11-18-2017, 11:56 PM
texinwa's Avatar
texinwa
texinwa is offline
Mirrors are cheap on ebay
Old 11-19-2017, 12:07 AM
Sterling6.7's Avatar
Sterling6.7
Sterling6.7 is offline
Old 11-19-2017, 03:25 AM
seville009's Avatar
seville009
seville009 is offline
I’d try WD-40 first - I lube mine every year; helps alot as they seem to dry out easily
Old 11-22-2017, 11:38 PM
iron butterfly
Thank you all for the replies and am going to try the gears from Graven parts. I'll update when I get them. All y'all have a great Thanksgiving!
Old 11-23-2017, 01:21 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
sounds like (if the gears are plastic which i am assumeing they are) you just need a quick shot of WD040 silicone spray (yellow can top) and that SHOULD cure the issue unless the teeth are broken on one or more of the gears...I do not have power folding mirrors but I do the same for the window motors and regs with moving parts every so often (including the window tracks on the side)
Old 11-25-2017, 12:58 AM
Sterling6.7
Looking forward to the update.....
Old 12-10-2017, 10:45 AM
Sterling6.7
Any news on the repairs?
Old 01-20-2018, 09:17 PM
Sterling6.7
Any updates?
Old 03-21-2018, 08:41 AM
rob17's Avatar
rob17
rob17 is offline
Where did you apply the WD-40?
Rob
Old 03-21-2018, 09:59 AM
seville009's Avatar
seville009
Rob
inside the pivot point where the mirror “hinge” is. Just stick the straw on the spray can as far inside the plastic cover as you can. I don’t take anything apart. After i spray it, i fold/unfold it a bunch of times to work it in.
Old 03-21-2018, 10:03 AM
rob17's Avatar
rob17
rob17 is offline
Thanks so much, I'll give that a try.
Rob
ubereal2
2009 - 2014 F150
04-26-2017 08:20 PM
antwan181
08-20-2016 10:00 PM
kper05
6.7L Power Stroke Diesel
08-02-2014 09:15 AM
zonedar
03-17-2014 05:57 PM
66F100Again
05-22-2009 02:59 PM
Quick Reply: folding mirror problems
