Hey Number
Old Nov 17, 2017 | 08:42 PM
pchelp's Avatar
pchelp
Hey Number
What does this break down as? 69' F100 2wd
Old Nov 17, 2017 | 11:24 PM
ultraranger's Avatar
ultraranger
Ford 9-3/8" rear end, 3.25:1 ratio, open (single track) differential, 3300# 31-spline axles. Rear end assembled the 3rd week of February, 1969.
Old Nov 18, 2017 | 07:20 AM
pchelp's Avatar
pchelp
Once again thank you Steve
Old Nov 18, 2017 | 08:56 AM
ultraranger
The Ford 9-inch rear end and the Ford 9-3/8" rear ends are very similar but only a few parts between 3rd members will interchange. Ring & pinion gears isn't one of those things that will interchange though. If the ring or pinion in that 9-3/8" rear end ever wears out or, a tooth gets chipped or broken off, there are no replacements for them --unless you could find some NOS gears or, a decent set of used gears. Aftermarket support for the 9-inch rear end is vast but, there's no support for the 9-3/8".
A 9-inch 3rd member will fit in a 9-3/8" rear end housing but a 9-3/8" 3rd member won't fit in a 9-inch rear end housing --at least not without notching the housing flange where the 3rd member bolts up.
Clearance notches (for the ring gear) shown on a 9-3/8" housing.
No clearance notches on the 3rd member-to-housing flange on this 9-inch rear end housing under my truck.
....I removed the 28-spline axles from the 9-inch rear end in my '69 F100 and replaced them with a pair of 3300# 31-spline axles from a '71 F100 that had a 9-3/8" rear end. I did this so I could remove my 3.50 geared, 28-spline, open differential, single vertical rib, 9-inch 3rd member and replaced it with a 31-spline, Traction-Lok, 3.50 geared, 9-inch, Daytona, N-case 3rd member.
My original '69 C7AW-E 9-inch 3rd member.
....replaced by this '75 D0OZ-B 9-inch Daytona N-case 31-spline Traction-Lok 3rd member.
Old Nov 20, 2017 | 09:15 AM
pchelp's Avatar
pchelp
Ok, so I am guessing you swapped it out because you wanted better highway cruising speeds? That's the thought I have tossing around. The RPM's are way too high around 70-75 mph
Old Nov 20, 2017 | 09:39 AM
ultraranger
The ratio (3.50:1) is the same between my original 28-spline 9-inch 3rd member and the 31-spline N-case 9-inch 3rd member I replaced it with so, no change there.
I did it because the N-case had 31-splines and a Traction-Lok differential and it's an N-case --the ultimate in strength for a 9-inch case. I only gave $75.00 for the N-case 3rd member and, I've had it sitting around for a number of years. It was cheaper for me to find some 31-spline axles from a '68-'72 F100 with a 9-3/8" rear end than it would have been to buy a 28-spline Traction-Lok differential, swap my ring gear over onto the differential and then have to set the gears back up.
I don't want to lose the rear end gearing. To remedy the problem of higher RPMs on the highway, I'll eventually remove the inline 240 and C-4 automatic and install an overdrive transmission --behind a fuel injected Ford small-block V-8.
Old Nov 20, 2017 | 09:46 AM
pchelp's Avatar
pchelp
I've been tossing around the idea of taller tires, less expensive.
Old Nov 20, 2017 | 09:50 AM
ultraranger
While that will slightly change things, it won't give near the full advantage that having an overdrive transmission would give you.
Tex51
Jul 31, 2019 04:18 PM
68Rookie
Mar 31, 2019 07:12 PM
Ricardo Chambers
Oct 19, 2018 12:33 PM
Pappys53
32
Apr 1, 2012 05:00 PM
papa's 64
1983 - 2012 Ranger & B-Series
May 13, 2007 04:13 PM
