So, the 65 would be the most likely option with the 285? Want to get tallest tire I can without rubbing. Have 2017 F250
I have 285/75r18 (34.8 "tall" and 11.2 wide) They did not rub before I put on my 2 inch BDS level kit and don't rub now.
37x11.5x20 tire will also not rub on a truck with a 2 inch level kit.
The problem with both those size tires is your choices are very limited. Only 1 tire I could find in the 37x11.5 inch Nitto Trail Grappler MT and there are not many option in the 285/75r18 either although there are a couple. I chose the Cooper AT/3
