Help with wiring harness
Old Nov 16, 2017 | 11:29 PM
wade427's Avatar
wade427
I have a 1988 F150 reg cab LB 4x4 5speed 4.9L I-6. I recently bought this truck and it has not run for a least 2 years. I put a new battery in and went to start it and smelled an electrical burning and unhooked the battery right away. I realized I had hooked up the battery backwards and when I connected it properly there was a wire that fried connected to the solenoid and the truck would not even make a click to start. I took the truck to a good mechanic friend, he replaced the solenoid, repaired several other things, tested all the relays and other points throughout the circuits. He has determined there is a short somewhere in the main engine wiring harness causing this wire short by the solenoid. To save time from testing all the wire harness, I would like to find a wire harness in a junkyard. I can not find a exact year and model truck. Can you help me with what variations I could use such as year range and/or engine? I know a harness for a 6 won't work for an 8, but can a wire harness for an 8 work on a 6 cylinder? Also, if you have any suggestions of anywhere else I can look to find a wire harness for this truck?
Chips2000
Jun 12, 2018 06:21 PM
wade427
Nov 16, 2017 10:46 PM
77 ford shortbed
Jun 15, 2008 08:29 PM
e william
Aug 25, 2007 08:31 PM
