Caster/Camber shims
I need to replace one of my upper ball joint shims. The first set of numbers I know are caster. The second set is camber. But I cannot find an answer if the ones from Autonation are specing 1/2° camber or caster??
https://parts.autonationfordwhitebea...OC1kaWVzZWw%3D
You would think since it says "camber kit" that it's referring to camber. BUT parts guy at Autonation says 1/2° is caster. I'm lost.....
My stock shims are 0° caster 0.4° camber on both sides. You can see why I want to replace the one...... I got alittle annoyed when it wouldn't come out one night and used a 5ft crowbar, little lip didn't like that very much
. Then I figured an easier way on the other side
Thanks in advance!
