Driveway alignment
got out the book and seen the eccentric upper ball joint. Twisted them around to get max castor and -.5 camber. re-adjusted toe and it drives like a new truck. Dead straight tracking on the highway.
Longacre Alignment Tools - RacingPlus.com
Everything Auto: DIY Wheel Alignment | Extreme How To, DIY - Do it Yourself, Home Improvement, Home Decorating
You can actually do a damn fine job with the angle finder from home depot.
FORD DODGE 4X4 CAMBER CASTER ALIGNMENT BUSHING KIT LIFT: eBay Motors (item 120627996867 end time Oct-06-10 17:21:58 PDT)
For $25-30 you can do it the easy way by taking it to a shop and have them just check the alignment and print out the readings for you. This well tell you how much it is off.
Take the nut off the top ball joint and you should be able to read the deg. of correction on the installed shim. Add or subtract to that reading to find out what size shim you need to order. Once you have this as close as you can get it to spec that you shouldn't have to change it.
Hardest part of this is getting the shims out if they are rusted in.
