2006 EGR and internal oil cooler were replaced after failing a couple years ago..
Does anyone know if the replacements (from Ford, done at a dealership) are supposed to be good to go? Or should I look at aftermarket stuff and a delete?
As long as they did an appropriate flush first you should have many years of service with regular coolant drains and refills.
Like said above, watch your oil and coolant temps. and as long as everything is in check there's no reason to replace.
