Howdy fellas,
Noticed my service engine light was on. Took it to Autozone and they found error code P012D Turbocharger Inlet Pressure Sensor was bad. Ordered a new one for $37. I'll change out the bad sensor for the new sensor.
You can do one of three things. You can drive it and let the truck reset it itself bit that could take up to 1000 miles, You can disconnect the positive (red) battery cable the keeping it well clear of the battery jumper it to ground, or 3 use a scan tool to clear the code.
You are correct because of possibly arcing with the wrench.
But as an electronics tech we are taught to remove the hot side and leave all grounds connected, then short the positive to ground through a resistor.. This will help drain any capacitors.
I'm also trained as an electronics tech (40 years). Automotive stuff sometimes has exceptions to the normal bench electronics procedures, this is one of them.
Did someone at Autozone actually help you with the code reader? Most will loan you the reader but won't hook it up or clear codes for you due to liability reasons.
And yes, definitely disconnect the negative first and put it back on last. Also, I don't think a KAM reset will clear a DTC.
The Autozone guy reset the code for me. Its been a week now and all is well!
