Sponsored by: Auxito
Airbag code 22 please help
Old Apr 29, 2014 | 08:06 AM
Adakar's Avatar
Adakar
Hi recently I fix the code 32.
But now the light is on again with a 22 code
my truck is a f150 xlt 1998
I search in internet about this code but only found this
"safing sensor ouput circuit shorted to battery voltage"
Anyone can explain me what it means
please give me some instructions
Thanks a lot
Old Apr 29, 2014 | 01:36 PM
Bluegrass 7's Avatar
Bluegrass 7
The parts of the circuit that are all common is the clock spring, the front sensor and the side/safing sensor.
They all are monitored by the diagnostic monitor for a voltage that is too high. This is the short to full battery failure code 22.
Since you have been working on this system, you may have produced the short or missed it in the harness at some location..
Remove the positive battery cable for at least 30 minutes before working on the system to be sure you don't blow the bag.
A search on the net can find the circuit that shows the common parts of this circuit and how it is monitored.
Now you know what your looking for. We can't tell you where the fault is.
Good luck.
Old Apr 29, 2014 | 02:35 PM
Adakar's Avatar
Adakar
Thanks a lot for the reply
Yes I Disconnect the battery and wait 1 hr to work in the airbag
I already fix the 32 code, I dissasembly, clean and test the clockspring, no shortcuts.
Can you tell me please where are the sensors??
Thanks a lot for your help
Old Apr 29, 2014 | 04:34 PM
projectSHO89's Avatar
projectSHO89
Remove the NEGATIVE cable first.
It is only necessary to wait one minute, the RCM's backup power charge dissipates very quickly. A longer delay does not increase the safety factor since the charge is already gone in less than a minute. If a longer delay were actually needed, the factory service manual would specify something other than a one minute delay.
Old May 1, 2014 | 05:32 PM
Adakar's Avatar
Adakar
Hi
I fix the 22 code
then code 24 appears....
and now code 22 again.......
anyone can tell me where are the front sensor and the side/safing sensor??? to check them???
If you can help me with a picture I really apreciate that.
thanks a lot
Jonesy0027
2009 - 2014 F150
Nov 25, 2017 07:48 AM
bbgun
1997 - 2003 F150
Feb 9, 2013 07:52 PM
67and71_Carl
Mar 5, 2011 01:06 PM
rtazz17
Dec 31, 2009 05:06 PM
Skreamr
Sep 20, 2008 12:17 PM
