WOW! Never seen this before.
Old Nov 19, 2017 | 01:09 AM
mxer0022's Avatar
mxer0022
My OBD reader hasn't been plugged in for three weeks. I had taken it out to try to figure out what the hell was going on with the wife's car and forgot to put it back in.
Old Nov 19, 2017 | 04:40 AM
sc7903's Avatar
sc7903
I had the same problem but all has been fine since I disconnected, re-connected and moved the plug. Link with photo of the plug.
https://www.ford-trucks.com/forums/1...working-2.html
Old Nov 25, 2017 | 04:54 PM
EO2SeaBee's Avatar
EO2SeaBee
Mine has done this a few times over the years and it has always been the plug over the E-Brake assembly. I can sometimes get it temporarily straightened out just by bumping the wad of wires going to the plug by carefully using the tip of my shoe and bump the loom a bit. When I get to a good stopping place, I will shut off the engine, then unplug and reinsert the plug, clear the codes and get back on the road.
Old Dec 10, 2017 | 10:49 PM
Fert's Avatar
Fert
apply parking brake and pull release handle. should make it all go away. wierd how everything dies but the fual gauge going down the road.
Fert
Old Dec 14, 2017 | 09:20 AM
JKru's Avatar
JKru
I am currently having the exact same problems with my '16 SD. It's at the dealership as we speak for the second time this month. I use the E-brake religiously. I have left an voice mail with my Service Advisor & will let you know what happens!
How did yours work out? Any more problems?!
Old Dec 14, 2017 | 07:49 PM
Ferguson65's Avatar
Ferguson65
Mine did it 2 weeks ago. Every damn light on the dash came on, odometer went blank, low oil pressure and coolant overheat messages.
I use my park brake every time I get out. Crawled under the dash, unpugged connector at park brake and plugged back in. Issue is has not reappeared so far. Some pleasant day I will pull the pins out and tighten them up correctly.
Old Dec 15, 2017 | 12:27 AM
mxer0022's Avatar
mxer0022
all I did was unplug the connector at the park brake and plug it back in. No issues yet. Although my backup camera has gone all scrambled looking once but that's it.
Old Dec 15, 2017 | 10:57 PM
Fert's Avatar
Fert
I went having this issue nonstop it seemed for a few days then none for months, then a time or two. I have tried to push the connectors together more. I will try moving the connector and using some dielectric grease to make sure connection isn't lost in the future.
Fert
RM2738
6.4L Power Stroke Diesel
Oct 29, 2012 12:33 AM
jjames1967
Jan 16, 2010 09:56 AM
SgtPanarella
Jan 25, 2009 10:09 PM
cornutsoffroad
Nov 1, 2008 01:34 PM
