WOW! Never seen this before.
Old Nov 15, 2017 | 08:58 AM
mxer0022's Avatar
mxer0022
So I was leaving for work this morning and got about half a mile from home when all of a sudden my whole dash lit up like a Christmas tree and started playing Christmas music for me. All at one time I got an engine over temp (truck had only been idling for about ten minutes), oil pressure low, service advance Trac, service engine, and the heater turned off. I turned around to go back home and 100 yards later they all went away just to all come back 100 feet later and go away just before I got home. While the codes were set my dpf gauge and odometer were blank. Torque pro and the obd link app show no codes. Couldn't get my forscan app to connect to look at each module.
anyone had this happen or know what it could be? It hasn't come back since the second time it happened.
Old Nov 15, 2017 | 09:25 AM
mxer0022's Avatar
mxer0022
Got forscan to work. Here is a list of modules that set codes:
TCM
U0155:00-2E
PCM
U0140:00-2E
U0102:00-2E
U0151:00-2E
APIM
C1001:01-28
TCCM
U0100:00-0A
U0101:00-0A
U0121:00-0A
ABS
U0212:00-0A
U0137:00-0A
U0140:00-0A
U0155:00-0A
U0102:00-0A
U0151:00-0A
RCM
B0090:nine3-0A
BDYCM
U0100:00-8A
U0424:00-0A
TBC
U0100-20
U0401:82-0A
GPSM
U0422:00-8A
Hope this helps
Old Nov 15, 2017 | 09:33 AM
darren32's Avatar
darren32
WOW is right. I have no idea, hopefully Larry sees this thread....
Some kind of electrical problem. Most of the U codes are "lost communication with...."
Good luck
U0100:87 Lost Communication With ECM/PCM "A": Missing Message GO to Pinpoint Test A .
U0121:87 Lost Communication With Anti-Lock Brake System (ABS) Control Module: Missing Message GO to Pinpoint Test B .
U0182:87 Lost Communication With Lighting Control Module - Front: Missing Message GO to Pinpoint Test C .
U0212:87 Lost Communication With Steering Column Control Module: Missing Message GO to Pinpoint Test D .
U0401:00 Invalid Data Received from ECM/PCM A: No Sub Type Information RETRIEVE and REPAIR all non-network DTCs set in the PCM. REFER to Section 303-14A (gasoline engine), Section 303-14B (diesel engine) or the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
U1000:00 Solid State Driver Protection Activated - Driver Disabled: No Sub Type Information GO to Pinpoint Test E .
Old Nov 15, 2017 | 12:01 PM
69cj's Avatar
69cj
If it's still under warranty I'd get it to the dealer ASAP. Probably would even if not covered. Could be a bomb waiting to go off at the most inopportune time.
Old Nov 15, 2017 | 02:05 PM
Nipperdog's Avatar
Nipperdog
Sounds like one of the Control Modules is having a Nervous Breakdown
Old Nov 15, 2017 | 03:24 PM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
I gotta agree with Mike, get that thing in the shop before you're on the side of the road calling for a flatbed. It's ticking.
Old Nov 15, 2017 | 10:20 PM
Sterling6.7's Avatar
Sterling6.7
Sounds like one of the plugs might be coming loose. Check the large ones on the firewall and down by the e-brake. Do you set the e-brake regularly? If so, might check there first.
Old Nov 16, 2017 | 10:42 AM
mxer0022's Avatar
mxer0022
I'm gonna be taking it in to get serviced Monday but won't be driving it until then. It's still in its ESP coverage. I purposely didn't clear the DTCs because I planned on having the dealership check it out.
I set my park brake every day when I get home. Our driveway is on an 8% grade so info it to save the tranny.
Old Nov 16, 2017 | 11:51 AM
djousma's Avatar
djousma
There is a large connector right next to the parking brake up under the dash. You might check that out. This has happened to other guys, where that connector has some contact with the parking brake, and has worked loose.
Old Nov 16, 2017 | 12:47 PM
my_crib_too's Avatar
my_crib_too
Might be the grey plug near the emergency brake. I had an issue 15/18 months ago. Same thing where the entire dash lit up and codes were set. Being a member here, I checked the grey plug and it was a little loose. Took it in and the dealer had it a week and could not find anything. Reset the codes and said to bring it back if it happens again. Nothing since.
bruce...
Old Nov 16, 2017 | 01:34 PM
T diesel's Avatar
T diesel
X2 on the E brake location connection.
Old Nov 16, 2017 | 09:36 PM
mxer0022's Avatar
mxer0022
Thanks guys. I will look into that in the morning. I will keep everyone updated.
Old Nov 17, 2017 | 01:34 PM
SkiSmuggs's Avatar
SkiSmuggs
Christmas music? It could have at least waited until after Thanksgiving.
Old Nov 18, 2017 | 03:08 PM
mxer0022's Avatar
mxer0022
I think that's what pissed me off more than the actual problem. Things are getting out of control.
Old Nov 18, 2017 | 07:34 PM
gwg42's Avatar
gwg42
In addition to above try not using your OBD bluetooth adapter. I had a whole series of issues, not identical to yours; but all weird. Ford could never find any thing wrong. Pulled my OBD adapter that I had successfully used for 2 1/2 years, Next month drive without any adapter. No weird issues, everything very normal. Bought another high end adapter and have used for several months. Ford tech thought perhaps OBD adapter was starting to fail, but no one knew any thing for sure. Mine threw codes, completely blanked out the screen, speedometer completely died; truck ran perfectly, then repeated everything. Close to Ford dealer so took it truck to their service department. Happened on Vact in Canada in Aug of this year.
