Sync 3. Ver. 2.3
Old Nov 16, 2017 | 08:43 PM
  #31
Spoojr's Avatar
Spoojr
Originally Posted by gpf2ez
I decided to go back out and do a MR. I started the truck and before I got into the menu I received a message that the updated completed. I verified that I am now on 2.3.
Interesting...so it completed while the truck was off? Mine has been 24 hours already, so I suppose I’ll see what it does tomorrow. If nothing, I’ll just do a MR and try again.
Old Nov 16, 2017 | 08:45 PM
  #32
gpf2ez's Avatar
gpf2ez
I'm not sure, but yeah it sounds like a MR is the next step for you.
Old Nov 16, 2017 | 09:09 PM
  #33
itzwolf's Avatar
itzwolf
Originally Posted by Fr8dog69
I downloaded it from here, it may require a login or setup of an account:
https://owner.ford.com/tools/account...html#/download
Thanks! I setup my account and downloaded the update tonight, now to find time to install it.
Old Nov 17, 2017 | 07:29 AM
  #34
GABAR's Avatar
GABAR
How big a thumb drive is needed for this 2.3 update?
The Ford Owner website recommends a 32GB but some have used smaller thumb drives for the update with success.
If I were you, and this is what I did, just use a 32GB and call it a day.
I didn`t have any problems using said 32GB thumb drive to download 2.3 from the website and uploading it to my vehicle which only took 25-30 minutes.
I`m not sure if you have one near you but I purchased a Verbatim 32GB 3.0 SuperSpeed USB drive from MicroCenter for $9.99.
Hope this helps.
Old Nov 17, 2017 | 07:33 AM
  #35
GABAR's Avatar
GABAR
Originally Posted by wb6anp
Any one else have a problem confirming the 2.3 update back to ford?
The update confirmation back to Ford/SYNC is done via WiFi even though it doesn`t say this on the website.
No need to try and do it via the USB after it`s removed from your vehicle.
Old Nov 17, 2017 | 11:15 AM
  #36
Spoojr's Avatar
Spoojr
Quick update: I’m sure it’s just coincidence, but when I turned off the truck last night I turned the radio off first. (Via the big power button). When I got in the truck this morning, it said the same “updating software” message, but then quickly went to the “update complete, restart” message, so it finally worked. Of note, it basically took 72 hours of total time, with approximately 3 hours of “truck running” time, to include 1 hour idling for my initial install attempt, and 2 separate 30 minute trips with the truck shut off in between. Overnight last night it seemed to finally finish up. I hope everyone else has a much smoother process.
Old Nov 17, 2017 | 11:24 AM
  #37
wb6anp's Avatar
wb6anp
thanks Ill go and try that.
Old Nov 17, 2017 | 05:16 PM
  #38
petei's Avatar
petei
Anybody know when the version 3.0 will be available?The new truck come with that already.
Old Nov 18, 2017 | 06:22 AM
  #39
GABAR's Avatar
GABAR
Hard to say.
Ford will release 3.0 to everyone when they think it`s ready regardless if it already comes stock on some new vehicles.
If you`re a rebel, 3.0 is already floating around out there in an "unofficial" capacity on some Ford Forums and many have downloaded it but just remember, it`s not "officially" released from Ford.
Hope this helps you out.
Old Nov 20, 2017 | 02:01 PM
  #40
ChuckS1's Avatar
ChuckS1
4wd Low
Updated my Job 1 truck from 2.0 to 2.3 this afternoon. Easy peasy. Most obvious change was the traffic fix, which was worth it by itself.
Old Nov 20, 2017 | 02:36 PM
  #41
screwy's Avatar
screwy
My truck updated itself it seems. While driving yesterday I noticed some small behavior changes with my radio, checked in settings and sure enough it says 2.3 now. I never did anything, though my auto-update is enabled and truck has wifi access in the garage.
Old Nov 21, 2017 | 05:12 AM
  #42
George S. Ellis's Avatar
George S. Ellis
Updated 2.2 to 2.3 yesterday. It took right at 30 minutes to get the Complete popup. Went into work, so the 5 minutes off was covered too.
Old Nov 21, 2017 | 05:32 AM
  #43
Whiplash2130's Avatar
Whiplash2130
Wink Thumb drive
I used a 4gb Drive, I think it wound up to be about 2.2 go.
Old Nov 21, 2017 | 05:33 AM
  #44
Whiplash2130
Wink Thumb drive
I used a 4gb Drive, I think it wound up to be about 2.2 gb.
Old Nov 21, 2017 | 05:59 AM
  #45
Dan Weyant's Avatar
Dan Weyant
Anyone had success in reporting that update back to the syncymyride site?
I've tried several times and it won't recongnize the file you are supposed to upload. keeps saying try again later.
