Modify or Sell ???
Old Nov 13, 2017 | 02:19 PM
afonda's Avatar
afonda
Modify or Sell ???
Hey FTE...
So I do a lot of fishing on the beaches at Cape Hatteras and some deer hunting too. Issue is off road capability especially on the beaches. As long as its flat ground, I'm good to go... but a little slope or soft sand and it's no good. She won't climb well or "float" over the softer sand (she sinks!!) Too heavy, and open difs... I have upgraded to 35's with a 3 inch lift, and some performance mods like tuner, exhaust, intake... But, i dont think she will ever very capable in the sand or on trails (easy to moderate trails, like fire trails)...
I could upgrade to selectable lockers, but not much else... (how much would that help?)
What can I do prior to deciding to sell??
Old Nov 13, 2017 | 02:30 PM
hydro man 17's Avatar
hydro man 17
I doubt that anything less than a sand rail would be very good at the beach.
Remember that these trucks weigh ~8,000 pounds. It would take some REALLY fat tires to keep from sinking in.
Old Nov 13, 2017 | 02:42 PM
Walleye Hunter's Avatar
Walleye Hunter
Are you letting the air out of your tires? I do not know what the prescribed pressure is for the beach but it is lower than normal.
Old Nov 13, 2017 | 02:45 PM
afonda's Avatar
afonda
Walley Hunter said: Are you letting the air out of your tires? I do not know what the prescribed pressure is for the beach but it is lower than normal.
Always air down to 25psi... can go lower if really needed.. down to like 18.. but risk the bead lock.
at 25 psi they are squatting good.
What about the lockers?
Old Nov 13, 2017 | 02:49 PM
brandon_oma#692's Avatar
brandon_oma#692
Right now you have 2 open diffs. I would think a Trutrac in the front and either a truetrac or Detroit Locker in the rear would help a bunch. What happens when you are stuck? All 4 tires dig holes? Or just 1 front and 1 rear?
Old Nov 13, 2017 | 02:51 PM
brandon_oma#692
I feel my current 2wd with a locker (locker not limited slip) outperforms my old 4x4 with an open front and stock rear limited slip
Old Nov 13, 2017 | 03:05 PM
afonda's Avatar
afonda
so whats in the front ... a Dana 60?
Can I get E-Lockers front and rear?
Old Nov 13, 2017 | 03:07 PM
afonda's Avatar
afonda
scenario goes... one tire spins front and back till bottomed out if I let it go that far... which i dont.. Sand is tricky... They dont switch back and forth like a Posi-track.. if thats what your asking..
Old Nov 13, 2017 | 03:15 PM
Walleye Hunter
What is your axle code on the door sticker? Then you can check on this list, way down the page, for what trucks that axle is in. I believe that my E-99 F-250 has Dana 50 up front but my '01 F-350 has Dana 60. You can also check tags on the axle. There are metal ones bolted to the cover and there is (or was) a sticker wrapped around the tube with a code on it, then you can find that code in a google search.
Super Duty Identification Codes
Old Nov 13, 2017 | 03:24 PM
brandon_oma#692
with that happening I would say a locker would help since you will have power to both sides. My truck will drive both sides now that I have the locker rather than spin the side with less traction.
Old Nov 13, 2017 | 03:29 PM
afonda's Avatar
afonda
axle code is 31. but Dana 50 or 60? how do you know? and how many splines?
Old Nov 13, 2017 | 03:31 PM
afonda's Avatar
afonda
I just got new tires and wheels $1700, new injectors a year ago $2000, repairs and lift last year about $1,500...
How much would e-lockers cost plus the install.. cuz I aint doing that install!!
Snag...
Old Nov 13, 2017 | 03:58 PM
Walleye Hunter
My E99 F-250 has the 31, I'm pretty sure that that is a Dana 50. The F-350 has a code of D1 and I am pretty sure that it is a Dana 60. I have to say that I did not check axle tags to confirm this. That would be the next step before I ordered parts for them.
Old Nov 13, 2017 | 04:52 PM
IDI-Charlie's Avatar
IDI-Charlie
Being an 02 you should have a 60 under the front. Easiest way to tell is to look on your right axle tube, if stamped 229 it is a Dana 50, stamped 248 you got a Dana 60.
As far as a new carrier install, it definitely wouldn't be cheap - while in there I'd go ahead and do all seals since the carrier has to come out to do those - not the funnest job. Plus you have your axle tubes out, may as well do u joints, etc... All in how much you're willing to do while in there.
Old Nov 13, 2017 | 05:23 PM
Colorado350's Avatar
Colorado350
Lockers pffft! You don't need no stinking lockers!
Check out this video on YouTube:
