The cruise control has been working intermittently, I took it to the dealership and they replaced a part to the cruise control that was recalled under warranty. The cruise worked for a short time, and now it isn't again..
I've asked people about symptoms of electrical and other problems that could be causing this, the most common question is "is the red ABS light on in your dashboard?" it is not on or illuminated...
Does anyone have/had this similar issue, and could you help me please??
You should post in the Diesel form.
I am not familiar if the CC is different on your truck.
What part was replaced and how does it act other than it doesn't work.
On gas models the master cylinder has a pressure switch that controls CC.
12 volt power goes through the switch to the CC.
If that switch was replaced with an after market make, it may still be an issue.
Good luck.
