How do you tell if the OBDlink MX is working right? IT still will not connect. I have tried Truck running not running . foot on brake . foot off brake Push button on the OBD AND hold button. I have tried everything i can think of. Still no go.
Click Start, then click Settings, then click Devices, then on the left click Connected devices. Do you see your bluetooth adapter here? If not, click add a device and see if you can get it connected.
The code that I was thinking of is provided to you after you register on the forum. Once an admin has approved your account the code will be provided to you and you enter that in within the forscan app that you downloaded. Follow the instructions on the ForScan Spreadsheet thread and it will work fine.
