Heres an idea...
Old Dec 14, 2009 | 10:47 PM
roostercrows's Avatar
roostercrows
Heres an idea...
Has anybody ran a Webasto on their trucks to help with cold starts? I've been thinking about it the last couple of days and wondered what you guys thought.
Old Dec 14, 2009 | 11:39 PM
Stewart_H's Avatar
Stewart_H
Is plugging in your truck not working?
Stewart
Old Dec 15, 2009 | 06:56 AM
roostercrows
No its not that, its more the lack of ability to plug it in. At work i can't plug it in from 6 to 6 which is obviously a long time, let alone going out of town for the holidays or whatever, my reasoning is that a plug is not always available and it would be nice to have an alternative...... or would it?
Old Dec 15, 2009 | 07:32 AM
99F-350CrewCab's Avatar
99F-350CrewCab
I remember the guys on the Shade Tree Mechanic show installing a system like that on a dodge. I looked around and couldn't find the episode or any information on it, but I did find another discussion on it with some good information.
webasto.htm
I could see this as being very useful if you don't always have a place to plug in.
Old Dec 15, 2009 | 09:50 AM
SkySkiJason's Avatar
SkySkiJason
With a properly functioning GP system, these trucks will start at well below 0*F without trouble. 'Plugging in' will make it quieter/smoother at start-up and help get cabin heat sooner - but is not required. If your temps are that cold, try switching to the lighter weight synthetic engine oil the manual suggests for cold temps. 5w40??? I forgot...
Also, a functioning hi-idle and EBPV together will help it warm up while sitting still, but it is generally more economical to just drive 'easy' until operating temp. If warm-up is still slow ya might consider a 'winter front' that restricts some airflow to the radiator. I think if you were in 20-30* below temps and could not plug'er in, the fuel-fired heaters would probably be a good idea.
Old Dec 15, 2009 | 11:30 AM
superduty4x4's Avatar
superduty4x4
Just leave your glow plugs on for at least 30 seconds before you try to start it and you should be fine.
Old Dec 15, 2009 | 08:43 PM
roostercrows
Thanks for all the feed back guys. 99f-350crewcab that is an awsome link thanks!
The main thing for me too is that of all the things we do to/ put our trucks through, cold starts are the hardest on them, I'm just looking to alleviate that as much as possible.
Is this a waste?
Old Dec 16, 2009 | 09:29 AM
SkySkiJason
Originally Posted by roostercrows
Is this a waste?
Unless you are in constant sub-zero temps and cannot plug in - YES! imho.
The hardest thing about 'cold starts' on these engines is blow-by. Diesels and other high-compression engines don't make full compression until operating temp. In the meantime, some combustion gasses (and possibly unburnt fuel) make it past the rings and contaminate the engine oil. Diesel engine oil is specifically designed to compensate for this. IF you are still worried about 'premature engine wear', get a UOA and rest your worried mind! Hell, you'll prolly end up saving money by extending your oil change interval (per the UOA suggestions).
Old Dec 16, 2009 | 09:50 AM
99F-350CrewCab
I'd consider putting one in just so I don't have to climb into a cold truck. It was 10 deg F here this morning and I don't think my block heater is actually working. Truck started fine, but that seat was a bit chilly. That's the main reason I don't drive the truck in the winter that much.
Old Dec 16, 2009 | 11:06 AM
SkySkiJason
If your block heater looks like this, its prolly not working!
This is more better:
Btw, screw 'economy'! I let my trucks warm up (1100rpm hi-idle on DP-Tuner) for 5-10mins when its cold outside. MPG's are down from avg 18.5 to about 15 in the last tank for this reason!! My butt is fine with that - cold seats suck!
FWIW, it was in the single digits last week here in NW Texas with up to 40mph winds (freaking COOOLD, by my standards!). The 216k mile Excursion with factory GP's, etc started same as always, but was a little grouchy for about 2 min's. Not plugged in, since I'm staying in a hotel. If I let it idle, it automajically raised idle to 1100-1300rpms and activated EBPV. In 10 mins it was near 'normal' range on temp gauge and almost comfortable inside.
Old Dec 16, 2009 | 12:20 PM
ron's power stroke's Avatar
ron's power stroke
for what its worth....the PCM waits for the oil to warm enouph to flow like it should before it goes into high idle....for that reason i only use my DP high idle after she has been run.....
Old Dec 16, 2009 | 12:48 PM
Smokin''s Avatar
Smokin'
Smokin
I've been starting a nearly 200k truck in negative temperatures here the last week or so. I think -25 was the coldest it got.
Truck will be fine, it'll start if everything is functioning normally. 5w-40 syntheic helped immensely, I must say.
Old Dec 16, 2009 | 02:31 PM
Kajtek1's Avatar
Kajtek1
Webasto are nice heaters but pretty expensive.
Is the extra comfort worth $2000 to you?
I know Webasto from RV applications. The system is pretty complicated and not famous for reliability. Several pumps and sensors where a single failure will shut it down.
Than not too many mechanics know what they are. Unless you are close to big marine repair business, you might have hard time to find anybody familiar with it.
Old Dec 16, 2009 | 02:46 PM
SkySkiJason
Good point! When its THAT cold, I just let the PCM do its thing! But I always let it run a minute or 2 before flipping the chip into Hi-Idle. IIRC, Jody mentions ya shouldn't use hi-idle and remote start - partially for the reason you mentioned!
Brrrrrrrr Lisa!!!! I really think I like the sub-tropical climate the most! Going to central FL next week for that very reason!!!
Old Dec 17, 2009 | 08:39 AM
99F-350CrewCab
Can you really put a price on having a warm seat without having to go out and start the truck?
I saw the price on a few websites, and it seems a bit steep to not have to walk out and start the truck. Didn't know about all the other issues with that setup.
I wonder what it would cost to convince one of the neighborhood kids to start the truck for me in the morning.
