Seat foam question
Old Nov 12, 2017 | 06:39 AM
KOT390's Avatar
KOT390
Seat foam question
Anyone know of a supplier for a replacement seat foam set? I would like to rebuild my bench seat but cannot find any replacement foam. I have a 1970 Ranger.
Also, I actually would like to put buckets in it if I can't find the foam for the bench, if anyone knows of a set of buckets just lying around
Thanks
KOT 390
Old Nov 12, 2017 | 03:54 PM
CougarJohn's Avatar
CougarJohn
I think you need standard household upholstery foam cushioning. Any upholstery shop can sell you what you need. Trim it to suit.
Old Nov 12, 2017 | 08:39 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
I used a combination of foam. 12lb, 1" foam, topped with soft anti-microbial 1/2" 8lb foam, that has a loose mesh of nylon to give it tear-resistance. I topped it with an extravagant layer of un-coated Cordura (heavy nylon pack-cloth) to resist dog-toenails, and a semi-modern automotive fabric top.
A fabric store had some closeout automotive UV-resistant velour. It was supposed to be ex-GM material from the 90's.
Overkill, but it has been very durable, breathable, quiet, and comfortable. The tough inner construction supports the foam, and keeps it from getting damaged under the fabric. Mine is a work truck.
Old Nov 13, 2017 | 10:06 AM
MIKES 68 F100's Avatar
MIKES 68 F100
Here's alink to my Interior redo thread , pics are gone (thanks photobucket *#@!)
in there I have a link to website for High density foam . they sell it at a good price .
that along with some burlap over springs (keeps springs from digging into foam)
Have fun
https://www.ford-trucks.com/forums/1...make-over.html
Old Jan 13, 2018 | 07:15 PM
KOT390's Avatar
KOT390
Have fun
Thanks Mike! I will check the reference you listed. I looked at my seat and finally realized what you all meant. I was originally thinking it would be like the dentside seat foam.
Update:. Actually I just looked through your thread and didn't see a reference for the foam and burlap. Just a reference for the carpet. Thanks
p.s. do you know approximately what size pieces of foam I need for the seat and the back? Thanks
Old Jan 15, 2018 | 05:08 PM
MIKES 68 F100
hmm 1.5" thick high density. measure seat and add a couple inches to be safe.
martinkik
Mar 14, 2019 03:15 PM
Tveter50
28
Jan 5, 2012 08:19 PM
rhopper
May 2, 2011 07:21 PM
79F150400M
Jan 28, 2009 10:19 AM
jseim44
Mar 27, 2008 03:57 PM
