Bench seat springs / Wood - Ford Truck Enthusiasts Forums
Old 02-27-2019, 01:40 PM
martinkik
martinkik is offline
martinkik is starting off with a positive reputation.
Hey guys,
At the moment, I stripped my bench seat backrest to the bare frame, because my upholstery was in terrible state.
Looking at it, I thought it might be possible to use a wooden backplate ( instead of the springs ) and glue some foam on it, and upholster it.
Does anybody have experience with this ? Or will I dearly miss the springs ??
Thanks guys,
Martin
Old 02-27-2019, 02:05 PM
Coastal68's Avatar
Coastal68
Coastal68 is offline
Coastal68 is gaining momentum as a positive member of FTE.Coastal68 is gaining momentum as a positive member of FTE.
What are you trying to accomplish? A stiffer seat? Are you trying to save time? Money?
Old 02-27-2019, 02:16 PM
martinkik
Hi Coastal,
In the first place a stiffer seat. And, as replacement parts are hard to come by in the Netherlands, a good and cheaper solution.
Thanks,
Martin
Old 02-27-2019, 02:41 PM
Coastal68's Avatar
Coastal68
I understand. I have had a similar idea. My F-250 seat is too bouncy.
With the right skills I think your idea is certainly do-able. Part of your challenge will be finding and buying the right kind of foam. There is a whole array of stiffness and quality to choose from and the various foams can be combined to achieve the desired effect. I feel sure someone who has done something similar will chime in any minute.
Also, if you can find a late 90s Ford pickup seat in the Netherlands, that might be a good option as it is a much stiffer seat and it will bolt in to your truck.
Old 02-27-2019, 03:12 PM
martinkik
We are locally blessed with a good upholsterer in the area, whom are selling and advising on materials such as foams etc., so I'll pay them a visit. Also, I'll check for a late '90's bench, if for sale.
If anybody else wants to share experiences, please feel free !
Thanks Coastal !
Old 02-27-2019, 03:37 PM
hivoltj's Avatar
hivoltj
hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
There is a build thread in this section where a user built a metal seat pan and used modern foam. It was a 4bt Cummins swap build... f100today I believe was the builder.
Old 02-28-2019, 03:43 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
"HioSilver" also rebuilt his bench seat.You can look up his thread.
I found it. "HIO Silver's Lo-Buck Bumpside Build" pg75
Old 03-01-2019, 12:30 AM
martinkik
OK great ! I'll go through these threads and find out !
Old 03-01-2019, 02:49 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.
I reupholstered my seat my self .
I replaced the factory nasty old foam with High density foam 2" thick . It worked out great made the seat much firmer and more comfortable . just be careful to much foam thickness and you will be kissing the steering 24/7
Pictures in my link below
Old 03-04-2019, 09:56 AM
martinkik
Hey Mike,
Thanks for sharing the pic's, you did a great job !
But, I was wondering if anybody deleted the seat-springs and used a wooden/steel insert, to achieve a more firm seat/backrest. And to stop bouncing around in the cab :-)
Thanks !
Martin
Old 03-04-2019, 10:00 AM
MIKES 68 F100
Thanks
Personally I think removing the springs and replacing with wood would make it to stiff, plus over time the wood would crack and break.
Old 03-04-2019, 06:40 PM
wauto
wauto is online now
wauto is starting off with a positive reputation.
School bus seats are made out of plywood and foam.
Old 03-14-2019, 03:15 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Talk to your upholsterer and see if he can custom form some foam and material to mimic bucket seats for the bench. That would look awesome IMHO. Plus adding seat belts with shoulder belts would help keep you in place.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
