11/99 4wd F250 ABS system
I was just writing in someone else's thread about hunting down an ABS light problem.
I could use some help figuring out my ABS system.
As far as I can tell and understand things, the first 7.3 SuperDuty F250s, with four-wheel drive, do not have any front wheel ABS.
The ABS instead uses a signal from the VSS on the rear differential. But for that to work the ABS, there has to be something to compare the speed signal to.
And I think that is a sensor on the transmission?
Do I have that correct?
My ABS light suddenly came on one day about 2 months back. A minute or two later, the speedometer quit working and has never come back. The next time I moved the truck forward from a dead stop, the Overdrive light started blinking, and continues to do this right as I pass 1800 rpm for the first time. Then it just blinks till I turn the truck back off. I have yet to have any success trying to pull out a stored code after several attempts on several scanners.
When I turn the key on, the ABS light comes on right away and never goes out.
I already replaced the VSS. So probably the problem is in the wire going back to the front of the truck ... or whatever else the ABS system works off. ?
More electrical gremlins - the speedometer would only work, sometimes, before this happened. The drier the road conditions, the more likely it would work. After this happened, for a while at least, the speedometer would sometimes work - but only when the road was very wet.
And fun with scanners - years ago, the lower 12v power port would throw a spark when I tried to plug something in to it, and I couldn't get any power out of it either. I never sorted that out and just used the upper port with no issues. Trying to use a scanner, someone asked me if the lowr port worked; I said no. I was informed that the scanners won't work if this power port is not working, and it has it's own fuse. I can't find any blown fuses - and this port works perfectly fine now.
So on my 99.5 I could buy the font abs sensors and just hook them into the wiring plug on the frame rails and onto the font hubs, and have 4 wheel abs without changing the PCM or anything?
OP, by scanner are you referring to a wireless ob2 sending unit to a Torque Pro or ForScan app, or the big dated bulky corded LCD screen units?
Again, I have never done this. But, anything is doable with the money and resources.
I want to just figure the system out. My front hubs have no wiring to them at all, so I am pretty sure I have rear wheel ABS only.
But how does the ABS figure out when to engage? Just the speed data from the VSS doesn't seem like it would be enough.
I suspect the PCM uses a signal from the transmission, and this signal is currently corrupted in some way. How does the trans communicate with the PCM?
