Firewall Grommets
Old Nov 10, 2017 | 08:28 AM
AlsRyd66's Avatar
AlsRyd66
Firewall Grommets
As I get to finalizing this build, its the smalls that are getting me now. What are ya'll using for the choke cable and speedometer cable grommets through the firewall? Also for the brake pedal push rod? PO had nothing there. For the pedal rod, it is aftermarket so, figured I could just make my own and have it bolt on with the power brake booster to the exterior side? Thoughts? Or guidance?
Old Nov 10, 2017 | 09:32 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The speedometer cable didn't have a grommet as such but used a foam sleeve that goes in the hole where the cable goes through. Here's a pic of an NOS speedo cable. the longer piece of foam blocks the firewall hole. The shorter foam piece holds the cable away from the trans so it doesn't chafe, which not all cables had depending on application.
Chad
Old Nov 10, 2017 | 12:10 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's the shot from the MPC of the heater cable - looks like it has a similar foam piece (circled in red) as the speedometer cables. One of my trucks has a remnant of that piece of foam. I think over time the foam either dries out and falls off or turns to a black tar like ooze, depending on climate.
Name:  heater cable.jpg
Chad
Old Nov 10, 2017 | 07:17 PM
AlsRyd66's Avatar
AlsRyd66
Thanks Chad. Lots of help. I'll make a foam sleeve for the speedo and choke cable. Figure I can make some from pipe insulation. My speedo had neither sleeve nor does the heater cable.
Al
Old Apr 6, 2024 | 09:40 PM
Dodgeyaussie's Avatar
Dodgeyaussie
Old *** thread but a search for a similar question bought me here.... found this on DC.... https://www.dennis-carpenter.com/tru...le-to-firewall
GJinVA
Oct 17, 2012 05:32 PM
olelepoint
18
Dec 15, 2009 08:44 AM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
baddmove
Bronco II
Feb 17, 2009 11:33 AM
Nathan
Apr 30, 2001 03:40 PM
