if i remove the intake can i replace the most forward drivers side valve lifter without removing the head?haynes book says remove head,chilton and ford shop manual don't mention removing the head.
i have one that needs to be changed but theres a guy on the ranger forum that says he tried and the head has to be removed.at this point im leaning toward leaving this a five cylinder.no way am i removing the head.it was hard enough removing the valve cover.
I've done this on a few 3400 GM v6 engines. Just unplug the fuel injector.
