Valve replacement procedure
Old Aug 10, 2019 | 03:08 PM
Ian Roach's Avatar
Ian Roach
I think I have a bent valve. I’m going to remove the cover tomorrow. How do I remove the bad valve? I can’t seem find instructions on how to remove a valve.
thanks in advance!
Old Aug 10, 2019 | 09:51 PM
mfp4073's Avatar
mfp4073
you will have to get more involved than the cover. To replace a valve you need to pull the head off. Once you do that its going to be some work to get the bent valve out of the head as the shaft is no longer straight.
they are all similar. This shows how to remove a valve.
