Duralift install
Old Nov 7, 2017 | 09:45 PM
Jon143's Avatar
Jon143
Duralift install
Ready to do duralift install (40222) wanting to know little bout the wiring side of it... I see ppl use relays and silinoids but I was wondering. If a inline fuse will be enough and what size I'm new to wiring stuff what Guage of wire also thanks for your helps
Old Nov 8, 2017 | 02:28 AM
Charmalu's Avatar
Charmalu
Yeah I have a 40222 also to install. I have a bunch of threads I saved to a folder.
Here is one on how to wire it,
https://www.ford-trucks.com/forums/8...ml#post8280861
Iam thinking of using the Packard Delphi connectors. there are a lot of sellers of these.
Here is one vendor to show what they are.
https://www.iwterminal.com/packarddelphi-terminals
They make a water tight seal, and if you need to remove or disconnect the pump, makes it easy.
Found this Video explaining them.
The crimper he is using does the crimp in one step, but is pricy. I have seen some on
E-Bay or Amazon that does it in 2 steps for around $25 +
Charlie
Old Nov 8, 2017 | 03:33 PM
Jon143's Avatar
Jon143
Where the P O got power from for the pos pump i think thats part of the windshield motor?? I know it get 12v when key is turned to accessory so wondeeing if i can use this and throw in a inline fuse 30 to 40 amp and just run the negative to the frame
Where the P O placed the old pump
Old Nov 8, 2017 | 03:38 PM
Jon143's Avatar
Jon143
Lol its all jerried together looks like... I always have to let the pos pump run for like 3 minutes on the first start of the day DONT WASTE MONEY ON **** lol I didn't but the PO did lol learn from other owners mistakes
Old Nov 10, 2017 | 01:12 AM
genscripter's Avatar
genscripter
I wouldn't use the PO's wiring. Who knows how F'ed up that is, if it's running a relay from the windshield wiper circuit.
Run your own stuff. I've been running a duralift e-pump for years now. IIRC, I didn't run a relay. I think it only draws something like 5 amps or less. With something this minor, you can run 14-18 gauge wire no problem. Just run an inline fuse housing from the positive battery terminal, and wire it up to a switch on your dash. Then from the outlet side of the switch, run a wire to the positive wire of the e-pump. Then run a ground wire from the neg terminal on the e-pump to the frame or body.
It's pretty simple. (A friend of mine wires his stuff differently, but I don't like it. I'll put it here if you want, but I never do it this way. He likes it because it shortens the require wiring. Step 1: put an inline fuse on the positive terminal, and wire it to the positive on the e-pump. 2: Wire from the neg on the e-pump to your switch on the dash. 3: Put a short wire from the output of the switch to the dash ground screw. It does result in less wiring, but something seems fishy to me having the e-pump always hot. If the switch wire grounds out, the e-pump will just keep running forever.)
Old Nov 10, 2017 | 12:24 PM
PlumCrazy7's Avatar
PlumCrazy7
I did mine about opposite of above. Tapped into a fuse spot that's hot with key on under the dash, to a switch, to pump and pump ground to frame. My pump is just behind the cab on the frame so this is by far the shortest route for me.
Old Nov 14, 2017 | 09:11 PM
FordTruckfan89's Avatar
FordTruckfan89
I used a relay triggered off the fss to feed my airtex e8012s pump.
Kleenax
31
Oct 5, 2013 09:14 PM
vwfreak
Electrical Systems/Wiring
Nov 27, 2012 09:40 AM
DemonRace6
Dec 11, 2011 07:24 PM
Farmboypowerstroke
13
Jan 2, 2009 06:01 PM
peterjeff
Oct 8, 2004 09:53 PM
